Old 03-26-2009, 06:24 PM   #1
skylindrftr
skylindrftr's Avatar
Trader Rating: (26)
skylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfection
Feedback Score: 26 reviews
Z32 17/16 brake booster question
Okay, so I bought a 17/16 z32 brake booster for my full 300zx brake swap and it does not fit. Has anyone else had this problem? I noticed that the studs that go through the firewall on the z32 (M215T) are shorter than the stock non abs s13 brake booster (M23) in general. I can get only one side to bolt up, and the other two can never get enough thread through to the other side to fit a nut on it no matter how much and mess with it. Solutions, suggestions?
Thanks
skylindrftr is offline   Reply With Quote
Old 03-26-2009, 06:31 PM   #2
slider2828
slider2828's Avatar
Sorry mine 17/16 bolted right up from JTuned....
Turn and Burn!
Old 03-26-2009, 09:15 PM   #3
projectRDM
projectRDM's Avatar
Doesn't sound like the right MC. I've never seen one that didn't slide right on just as the original one did.
FORMERLY R240NA
Old 03-27-2009, 02:56 AM   #4
skylindrftr
Trader Rating: (26)
Hmm, like I said, it is a M215T unless someone switched the stickers on me. It does line up with the bolt holes on the firewall, it just has shorter studs than the stock s13 unit (M23), is it possible to take the studs out of the s13 unit in any way?
Old 03-27-2009, 03:11 AM   #5
projectRDM
projectRDM's Avatar
Studs don't come out, they're welded on.
FORMERLY R240NA
Old 03-27-2009, 03:56 AM   #6
fueled by hate
fueled by hate is making a name for him/her selffueled by hate is making a name for him/her selffueled by hate is making a name for him/her self
i think he's trying to use the actual z32 brake booster and not just the master cylinder?
fueled by hate is offline   Reply With Quote
Old 03-27-2009, 06:02 AM   #7
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
op, give us detailed pix of what you mean.
we'll be better equipped to help you then.
Old 03-27-2009, 07:33 AM   #8
g6civcx
g6civcx's Avatar
Are you sure there is nothing stuck in the way?
If not, then you can consider cutting off the stock studs and weld on longer ones.
Old 03-27-2009, 12:33 PM   #9
skylindrftr
Trader Rating: (26)
Yeah I meant the brake booster, not the master cylinder, the studs for it that go through the firewall are smaller than the stock 240sx ones, has anyone actually got it bolted up before? I will get pics later today.
