Old 07-15-2009, 09:56 PM   #1
Clawhammer
Clawhammer is making a name for him/her selfClawhammer is making a name for him/her self
Send a message via AIM to Clawhammer
JDM Sideskirts, S15 Turbo, SR20, Greddy FMIC, HKS BOV, 5 Lug, Shell, +more!
Most parts were bought BNIB, have receipts for everything FWIW.
Located in Gainesville. Can make arrangements to meet or travel down south. Not making any special trips for one part, I might make a day of it if I have a bunch of stuff to sell. Will ship at your expense (+paypal fee).
No trades, I don't want your junk.
Email: ryanfncrowson at gmail dot com
Motor:
We rebuilt the motor, so all new gaskets seals etc. Motor will need to be broken in! Small leak at the oil feed, before it's dropped in take it to a welder and give em 20 bucks to hit it with a fresh bead. Or JB weld it. (There's a -3AN fitting welded to the block that eliminates the banjo and crush washer system.) The new stuff have 0 miles on them. Almost everything else has <5000 miles.
Long block $1500
Valve cover to the oil pan. Will have flywheel, RAS, cams, HG, studs, tstat etc. Will not have accessories, exhaust manifold/turbo, fuel rail or injectors, or clutch.
http://c2.ac-images.myspacecdn.com/i...d3d04c4099.jpg
http://c3.ac-images.myspacecdn.com/i...c55374fb8e.jpg
http://c3.ac-images.myspacecdn.com/i...a26ec36f9e.jpg
If you want to add things to it you can choose from (or if you already have an SR):
S15 Spec R turbo package $750
Turbo (<5000 miles, NO shaft play, no smoke)
Stainless steel braided lines
Tubular manifold and copper exhaust manifold gasket
All new turbo gaskets
http://www.btyproductions.com/clawha.../FS/turbo1.JPG
http://www.btyproductions.com/clawha.../FS/turbo2.JPG
Enthalpy tuned ECU $350 (for S15 turbo, z32 maf, 550cc injectors)
http://www.btyproductions.com/clawhammer/240/FS/ecu.JPG
Custom S13 SR Wiring Harness $400
Braided sleeving, injector wires lengthened, maf wires lengthened to run under the dash and through the fender, body harness plug strands lengthened to run in fender, ingitors relocated inside with ECU, eleventy billion unused wires and plugs removed.
Index of /clawhammer/240/motor/Harness
Greddy S13 LS Spec Intercooler Kit $350 stock BOV nipple on hotside welded shut!
http://www.btyproductions.com/clawhammer/240/FS/ic1.JPG
http://www.btyproductions.com/clawhammer/240/FS/ic2.JPG
http://www.btyproductions.com/clawhammer/240/FS/ic3.JPG
http://www.btyproductions.com/clawhammer/240/FS/ic4.JPG
Greddy Hotpipe w/ HKS BOV $175 (with Recirc fitting)
http://www.btyproductions.com/clawhammer/240/FS/bov.JPG
Edge Racing 3" Turbo Elbow and Downpipe $120 Brand new gasket between them.
http://www.btyproductions.com/clawha.../elbow_dp1.JPG
http://www.btyproductions.com/clawha.../elbow_dp2.JPG
SR Starter $100 (New KA starter body with SR head swapped, starts instantly everytime)
http://www.btyproductions.com/clawha.../srstarter.JPG
SR Alternator $150 (Brand new remanufactured KA alternator ready to bolt to an SR)
http://www.btyproductions.com/clawha...0/FS/sralt.JPG
http://c4.ac-images.myspacecdn.com/i...d088060c53.jpg
Footwork stuffs:
Coils $1000 + your crap you'd throw away anyway
Stance GR+ Pro, <5000 miles on them, 8/6 springs loaded, 9/7 BNIB, wrenches, z32 lower mounts, z32 uprights, extra set of brand new camber plates.
http://www.btyproductions.com/clawha...S/footwork.JPG
http://c2.ac-images.myspacecdn.com/i...d4419f368d.jpg
5 lug $450 plus yours
Ichiba front conversion hubs, z32 rear hubs, s14 se's with tires with LOTS of tread left. See pic of exhaust above for tread.
SPL Tension Rods $150 + yours
Circuit Sports Inner/Outer Tie Rods $80 + yours
Misc. crap: (this list will probably grow)
Shell $1000 Stock suspension, brakes, 4 lug. If you want any of that stuff add the prices from above to it. Will come with S14 seats, viper alarm/keyless, professional tintjob, lifetime alignment at Firestone, mint and very complete interior. Engine bay spray bombed black. Pignose front with some dents in the fenders. Dent in the rear 1/4 below the big body line on both sides from idiots that can't back out of a parking spot (body kit/valances would cover them, should be able to pop them out easily also.) PM for more details. I see way worse shells go for more, so save the whining for your mother.
JDM Chuki 180SX Side Skirts $250
http://www.btyproductions.com/clawha...FS/skirts1.JPG
http://www.btyproductions.com/clawha...FS/skirts2.JPG
Greddy Boost Gauge $150
Buy both get the pod free!
Greddy Oil Pressure Gauge $150
http://c2.ac-images.myspacecdn.com/i...9e2de98d2d.jpg
Apexi Hybrid Megaphone Exhaust $350 (1pc very quiet super JDM 80mm goodness)
http://c3.ac-images.myspacecdn.com/i...557d957d32.jpg
http://www.btyproductions.com/clawha...FS/exhaust.AVI
Complete SR Head $200
http://www.btyproductions.com/clawha.../sparehead.JPG
S14 Front Seats $150
http://www.btyproductions.com/clawha...or/s14seat.JPG
^Passenger just as clean!
Grex Shift Knob $25
Redline Goods Shift Boot $25 (Italian leather, red stitching)
http://www.btyproductions.com/clawha...nobandboot.JPG
Nismo Motor and Tranny Mounts $170 installed never used.
http://www.btyproductions.com/clawha.../FS/mounts.JPG
Speed Panels with hardware $40
http://www.btyproductions.com/clawha...peedpanels.JPG
Chuki bumper $20 needs to be sanded
http://www.btyproductions.com/clawha.../redchuki1.JPG
http://www.btyproductions.com/clawha.../redchuki2.JPG
http://www.btyproductions.com/clawha.../redchuki3.JPG
Chuki bumper grills $10
http://www.btyproductions.com/clawha...hukigrills.JPG
SOHC AC Compressor $25
http://www.btyproductions.com/clawha...FS/accomp1.JPG
http://www.btyproductions.com/clawha...FS/accomp2.JPG
SOHC Alternator $25
http://www.btyproductions.com/clawha...40/FS/alt1.JPG
http://www.btyproductions.com/clawha...40/FS/alt2.JPG
SOHC Dizzy and sweet OEM rubber cover $25
http://www.btyproductions.com/clawha...0/FS/dizzy.JPG
Random filter $20 could use a cleaning
T25 Turbo Outlet $20
http://www.btyproductions.com/clawha...bo%20stuff.JPG
^inlet sold
S13 Padded Cup Holder Console Lid! $50
http://www.btyproductions.com/clawha...cupholder1.JPG
http://www.btyproductions.com/clawha...cupholder2.JPG
Single DIN Triple Gauge Plate $10
http://www.btyproductions.com/clawha...gaugeplate.JPG
SOHC/SR MAFS $20 w/pigtail
http://www.btyproductions.com/clawha...0/FS/srmaf.JPG
Clawhammer is offline   Reply With Quote
