Old 04-11-2009, 06:56 PM   #1
VNG704
VNG704's Avatar
VNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond repute
Rough wear on camshaft
So doing a timing chain kit replacement and noticed on the exhaust camshaft lobe under the third cap has rough scarring or wear around the lobe. what may have caused this? low oil pressure? I should let you guys know that I did a money shift 3rd to 2nd instead of 4th before the timing rattle if that info helps. I can post a pic if needed. Will this hurt my engine? Car drove fine like this, well except for the little rattling which came from the front of the motor which I asumed was the timing chain. I do have some hks cams but wasn't planning on putting them in yet. Probably not until I know what's going on with that cam lobe. thanks in advance.
VNG704 is offline   Reply With Quote
Old 04-13-2009, 01:00 AM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Check the oil dripper, could be clogged. That or you have low oil pressure issues...either way, good luck to you...
CLICK HERE!!!
Old 04-13-2009, 01:02 AM   #3
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
do you change your oil often? say every 3.5k miles. maybe that rattle was rod knock.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 04-13-2009, 07:03 AM   #4
fliprayzin240sx
If I was in your shoes, just so I can sleep at night...I'd drop the oil pan ASAP and check for gold. If you strike gold, time to save money for a rebuild or another engine/bottom end.
CLICK HERE!!!
Old 04-13-2009, 02:40 PM   #5
VNG704
VNG704's Avatar
I haven't gotten the chance to get see if the valve is bent/rocker arm play... yet. Someone said I may have a bent valve. It's been cold and windy and the way I have the car faced towards the garage door, I'd have the wind blow debris in the motor. I have it faced this way to use the sunlight versus the poor garage lights to work on the car. I kinda regret it because I have a hard time to work under the hood when it's windy, which is alot lately. It looks like dirt or something has gotten in there and f*cked it up. Also on the second pic, notice the discolored part of the cam, don't know if that has anything to do with it. I never noticed the rattle until the money shift. The rattle wasn't scarey rattling (I've heard sr20 rod knock on youtube *ouch*) and came from the front so I figured timing chain. I have the oil drained and oil pan off. It's about time for me to get some nap time before work but I'm going to check the oil for "gold" hoping I won't find any. I've only owned the car since right before winter and had it garaged. I haven't driven the car too much at all. I did have the oil changed right before winter. Anyway I took some pics to show you guys what I'm talking about.
from the top:
this one shows the wear on the part under the camshaft:
