Old 03-21-2003, 08:43 PM   #1
TheSparo
Location: Athens/Chattanooga/ Cookeville/Morristown, TN
TheSparo is an unknown quantity at this point
Send a message via AIM to TheSparo
how do i get the car here???
ok, so i am going to have to bring a 240 from ga to here (tn) and the clutch is supposedly too burned out to drive, so i was thinking i could rent one of those dolley things, where u put the front wheels on the dolley and it just brings the rear on its wheels, but i have heard it will mess up the drivetrain or something, is this true, do i just put it in neutral? or do i have to do something special? or will that not even work? thanx all
-jeff
TheSparo is offline   Reply With Quote
Old 03-21-2003, 08:54 PM   #2
AKADriver
AKADriver's Avatar
A tow dolly will be fine. It won't wear the drivetrain any more than if you drove the car that distance.
Old 03-21-2003, 08:55 PM   #3
TheSparo
ok so it wont **** up anything
Old 03-21-2003, 09:35 PM   #4
Bliss
Bliss is an unknown quantity at this point
Send a message via ICQ to Bliss Send a message via AIM to Bliss
Don't tow a RWD car with the rear wheels on the ground. The drive wheels aren't supposed to be movie without the rest of the car. Something about lubrication not going around, or something.
Bliss is offline   Reply With Quote
Old 03-21-2003, 09:57 PM   #5
oberkill
oberkill is an unknown quantity at this point
Uh not sure where you heard that but wherever it was you can dismiss it! LOL It is fine to tow it with the rear two wheels on the ground and the front on the tow dolly. I think it would be much more dangerous to do it the other way actually. Just be sure the car is in neutral and the e-brake is off and you will be fine.
Alan
http://www.project240.com
oberkill is offline   Reply With Quote
Old 03-21-2003, 10:07 PM   #6
boro240
boro240 is making a name for him/her selfboro240 is making a name for him/her self
with auto cars you need to disconnect the driveshaft when towing rear wheel, i dont THINK this applies to manual, but youd better research it, instead of just asking people on a forum.
boro240 is offline   Reply With Quote
Old 03-21-2003, 10:40 PM   #7
Integraholic
Integraholic is an unknown quantity at this point
I would lock the front wheels and tow it with the back. Unless you want all those miles put on the car without actually driving it. It'll spin the odometer the whole way.
Variable valve timing is like your girlfriend, everyone's doin it.
Christian, aka The Integraholic
1999 Acura Integra GS-R
Slower than poo
156 whp and 120 lb-ft
Integraholic is offline   Reply With Quote
Old 03-21-2003, 10:46 PM   #8
Bliss
OOhhk, there we go. That's what I was thinking. Sorry for the misinformation/
Old 03-21-2003, 11:02 PM   #9
240racer
240racer's Avatar
240racer is an unknown quantity at this point
I have towed many different cars all different ways. If the car is an automatic, there are a few things to keep in mind. One, the transmission is not meant to be turned with the car off, if you can have the car running, then it's OK, but not ideal. Usually the driveshaft is disconnected when the drive wheels are on the ground. I have towed cars without doing this for short distances in emergency type situations. With a regular manual transmission like a camero or 240sx, the driveshaft does not need to be removed to tow the car on the rear wheels. The transmission is not affected by the car running or not. I would not recomend towing a rwd manual car by the front wheels, it's a pain and there's no reason for it. Front wheel dollies work great, but they aren't much different then just using a Jeep style dolly that towes on all 4 car wheels. If I was towing my 240, I would use a dolly that leaves all 4 wheels on the ground. The front wheel dollies are mostly for fwd auto cars (the majority)
Adam
'89 coupe KA24DE+T
14.1 @ 104 MPH
'88 Celica All-Trac turbo
stock, but no more ecu codes!!
240racer is offline   Reply With Quote
Old 03-21-2003, 11:04 PM   #10
hooter
hooter's Avatar
hooter is an unknown quantity at this point
Send a message via AIM to hooter
According to the FSM, Nissan doesn't want you to tow 240sx with the rear wheels on the ground. They recommend wither towing it with the front wheels on the ground or with the rear wheels on dolly.
-Charlie
SHIFT_knob
hooter is offline   Reply With Quote
Old 03-21-2003, 11:05 PM   #11
96SEChick
96SEChick's Avatar
96SEChick is an unknown quantity at this point
I'd spring the extra $$ and rent a flat-bed trailer to tow the car on. I can't remember how much more they are, though. But, I'd research it just to be safe. Less of a chance for straps to be faulty (I know it rarely happens, but one of my friends had to be a poor sap who experienced it), no worry about the drive-train, etc.
Lauren
'91 300ZX TT Ultra Red 5-speed - JWT POPCharger, JUN flywheel, ACT clutch, Energy Suspension Bushings, Tokico Blues - dyno'ed 295hp/306tq
'94 300ZX TT Black Emerald Pearl 5-speed - JWT POPCharger, JWT ECU w/ Stillen chip, Stillen exhaust, Tokico Blues, Eibach ProKits, 18" Enkei RP-01 wheels - dyno'ed 333hp/385tq
'00 WS6 Trans Am Bright Red 6-speedFOR SALE - only 29k miles, stock, fully loaded, only $23,999 (NADA $26300)
Green Country Motorsports
Northeastern Oklahoma SCCA
96SEChick is offline   Reply With Quote
Old 03-21-2003, 11:21 PM   #12
Bliss
-Charlie
HEHE...score. Figured out how you're going to tow it, yet?
Old 03-21-2003, 11:51 PM   #13
oberkill
Just rent a complete 4 wheel off the ground "flatbed" type from U-haul. They are not expensive at all, thats how I towed my car when I moved. In the mean time since I posted I e-mailed a few people who tow their cars quite often and they always tow it with the rear wheels on the ground but they are all 5 speeds. GA to TN is a long damn way though! LOL I would not tow it with either 2 wheels on the ground, I would tow it with all 4 off. Or just change the clutch and break it in on the trip home!!!!
Alan
Old 03-22-2003, 06:43 AM   #14
TheSparo
ok, looks like i will just have to rent a flatbed trailer thing, sounds good, i appreciate all the help
-Jeff
