Old 04-16-2009, 01:31 PM   #1
pungkiteater_671
pungkiteater_671 is an unknown quantity at this point
soft brake pedal
ok so yesterday i was driving my car and my brake pedal felt a little soft but was still working fine and today when i was go to the store my brakes went to the floor and when ever i pump it gets stiffer
the only thing i did with the brake system is check if my brake pads were still good
what can be the problem i never messed with brakes but changed them on a 240 if its the master cylinder how do u replace it
pungkiteater_671 is offline   Reply With Quote
Old 04-16-2009, 02:42 PM   #2
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
bleed your brakes first. its an easy process and could be your problem.
could also be your BMC, but bleed your brakes first to be certain
lexus baby
5t341tH is offline   Reply With Quote
Old 04-16-2009, 02:51 PM   #3
pungkiteater_671
yah i will after school thanks i noticed some brake fuild on rims on the passenger side after i test drove it
Old 04-18-2009, 12:26 PM   #4
dubtastic
dubtastic is an unknown quantity at this point
you might be leaking from brake line hose/ bleeder screw if u see fluid on your rim
dubtastic is offline   Reply With Quote
