Old 04-04-2009, 08:08 PM   #1
midnightouge
midnightouge's Avatar
midnightouge is close to perfectionmidnightouge is close to perfectionmidnightouge is close to perfectionmidnightouge is close to perfectionmidnightouge is close to perfectionmidnightouge is close to perfectionmidnightouge is close to perfectionmidnightouge is close to perfectionmidnightouge is close to perfectionmidnightouge is close to perfectionmidnightouge is close to perfection
Need help, ecu won't turn on.
I've been searching for hours and sent out lots of PM's but i cant find a solution.
My car is a 91 ka24de, i was having idle problems for a wile, but now my car wont turn on. It cranks but its not getting any fuel because the ecu wont turn on for some reason. I replaced the EGI & EGI pump relays twice already with no luck.
I have also switched out my ecu for different one.
Anyone know of any other wires, relays, or fuses i should be looking out for?
Any info is appreciated.
Thanks.
Last thing i did before it started acting up was clean the PAIR valve.
I also replaced the fuel pump 4 days before i started having this problem.
midnightouge is offline   Reply With Quote
Old 04-05-2009, 03:05 PM   #2
cotbu
cotbu's Avatar
Did you by any chance disconnect the dash plug, while swapping ecu's? My car won't start without the dash plug connected. Don't ask me how I know!
I didn't get one screw this................!
Old 04-05-2009, 09:10 PM   #3
opponheimer
opponheimer's Avatar
opponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond repute
ECCS / ECU (Blue) relay may be bad
SR20 & RB20/25/26 in s13/s14 Wiring from $125 to $200.. Best prices EVER.
opponheimer is offline   Reply With Quote
Old 04-05-2009, 11:09 PM   #4
midnightouge
I doubt i disconnected anything, but I'll definitely looks at that tomorrow.
Thanks, I'll get a new one tomorrow.
Old 04-06-2009, 10:00 AM   #5
opponheimer
why. use a fan relay or something
Old 04-06-2009, 01:50 PM   #6
SouthFLSal
SouthFLSal is an unknown quantity at this point
This is a link to an awesome ECU diagram. I'd check all my power wires with a voltage tester, and then check all my ground wires to make sure it's all grounded.
"That's all I can say about that." Forest Gump
How to pull codes from an E5 blacktop ecu...anyone know?: SR20DET Forum (rear-drive): Nissan Forums / Infiniti Forums - NICOclub
SouthFLSal is offline   Reply With Quote
Old 04-18-2009, 01:36 AM   #7
midnightouge
Bump
If anyone can lead me to a solution, I will paypal you some money or something.
