Old 04-28-2009, 06:59 AM   #1
thetopcow
thetopcow's Avatar
thetopcow is an unknown quantity at this point
SR SR: Oil and Water out downpipe; Turbo?
Hello everyone,
I just wanted to verify my thoughts on a current problem I have.
Facts:
S13 Blacktop SR
Runs
Cylinder pressure is good
So my problem started when I noticed coolant leaking out around my cat delete upon initial start up/clean out runs. Then after leaving it over night, I came back to notice the container I was catching water in, now had oil in it.
So my question is and my current thought is: I have a blown turbo?
The engine had tons of carbon build up in numerous places, notably the cam squirters were plugged which cause abnormal cam wear. This would make me think the same crap was gumming up the turbo oil passages. The turbo had a bunch of oil residue in the compressor housing, which could have be blow by? The shaft play on the turbo seems minimal, but I am no turbo expert. O yeah, and there is white, smoke rolling out the tail pipe, probably from the water in the pipe.
Thanks for the help!
thetopcow is offline   Reply With Quote
Old 04-29-2009, 08:27 AM   #2
thetopcow
thetopcow's Avatar
Anyone? Just looking for a second opinion - A "yeah, your on the right track" would work.
Old 04-29-2009, 08:56 AM   #3
jspaeth
jspaeth's Avatar
Not sure how bad turbo seals would cause a water leak....didn't think you could leak water from the turbo.
Daily driven
Old 04-29-2009, 09:16 AM   #4
89jdm7m
89jdm7m is an unknown quantity at this point
sounds like head gasket to me??? but you said good cyl. pressure??? to be honest, i'm probaly as confused as you are
89jdm7m is offline   Reply With Quote
Old 04-29-2009, 02:04 PM   #5
Sileighty_85
Sileighty_85's Avatar
there isnt a gasket or seal for the coolant in a turbo its a passagway molded into the casting of the turbo.
so the water isnt from your turbo. Condensation maybe.
but do a leak down a compression test on the engine
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
