Old 04-22-2009, 05:45 AM   #1
sil8tyhavoc
sil8tyhavoc is on a distinguished road
Send a message via AIM to sil8tyhavoc Send a message via Yahoo to sil8tyhavoc
SOHC burning oil....
ok i recently got a valve job. got the car running. everything seems fine but it burns oil. the engine is practically new. new rings, bearings, pcv valve, etc. i compression tested it. 155 all across. could this be coming from the head ? bad valve seals maybe ? arent machine shops suppose to change the seals when you get a valve job? i really doubt its burning from the block. any ideas ?
sil8tyhavoc is offline   Reply With Quote
Old 04-22-2009, 06:40 AM   #2
Sileighty_85
Sileighty_85's Avatar
Preform a leak down test
Machine shops will only replace if you tell them to or if you give them the parts
did you pay for valve seals to be replaced? if not then more than likely they were not replaced.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
