![]() Join Date: Dec 2002
Help! :(
I hear this weird noise when I reverse sometimes, and it sounds like a loud rubbing noise, BUT I don't think my tires are rubbing. Also, there are no scuff marks on the insides of my fenders...any ideas as to what this noise could be? (BTW, I only hear the sound when I'm in reverse....)
E-mail: [remove]that240guy[remove]@gmail.com AIM: TehApologizer |
![]() Join Date: May 2002
check your brake pads (rear) improper wear (it may have been installed incorrectly) can lead to this problem (i had it on my car at one time)
You're slider pins on the calipers may be seized. It's tyupically a simple fix. Tear apart the slider pins, remove any build-up, and then add some grease(the auto parts store should have a grease designed for this application).
Ok, I'm guessing that it has something to do with the brake pads...I think I didn't lube the caliper slider pins....are the pins the ones that hold the caliper in place? I'm not exactly sure what they are....oh, and mrdirty, that's good advice....that was the first thing I looked for when I heard the sound
![]() Thanks you guys! You were all really helpful...I'll let you know what happens...! Thanks again! ![]()
Ok, this is an old topic and I still get the noises....what's weird is that the only time it makes noise is if I go from D to reverse...meaning it doesn't make a noise when I back out of the garage from park. And the noise is coming from my rear right wheel...it sounds like a very loud rubbing noise, but not like tires rubbing....
