Old 09-17-2008, 03:44 PM   #1
socal_kouki
socal_kouki's Avatar
socal_kouki has much to be proud ofsocal_kouki has much to be proud ofsocal_kouki has much to be proud ofsocal_kouki has much to be proud ofsocal_kouki has much to be proud ofsocal_kouki has much to be proud ofsocal_kouki has much to be proud ofsocal_kouki has much to be proud ofsocal_kouki has much to be proud ofsocal_kouki has much to be proud ofsocal_kouki has much to be proud of
SR20VET/SR20DET Frankenstein.
I've done a mild search for SR20VET head's on SR20DET bottom ends, and found little to nothing.
A couple of reliable people have told me it produces positive results... can anyone else offer any input on the subject?
This used to be a cool forum.
socal_kouki is offline   Reply With Quote
Old 09-17-2008, 03:50 PM   #2
jrbump
jrbump's Avatar
jrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond repute
It's been done. There are pics and threads here on zilvia.
jrbump is offline   Reply With Quote
Old 09-17-2008, 03:51 PM   #3
japside4life
japside4life is an unknown quantity at this point
did mazworx do this before?
japside4life is offline   Reply With Quote
Old 09-17-2008, 04:08 PM   #4
socal_kouki
Couldn't find the thread. I'd like to read up on it, I'll probably have to search elsewhere.
Old 09-18-2008, 12:38 PM   #5
Geno750
Geno750 is an unknown quantity at this point
Send a message via AIM to Geno750 Send a message via Yahoo to Geno750
They currently run this setup on their S15 drag car. The main issue with going to the VE head is the dizzy. It hits the firewall. Mazworx got around this by removing the dizzy and installing a hall effect sensor on the front of the motor (works kinda like the cam sensor on the det). There may be a kit for this conversion from Mazworx in the future.
Its a pretty good deal if you can get a ve head for about $1k. In stock trim, it will flow better than a ported SR head, and it doesn't have rocker arms (yay!). Also, the stock cams have some pretty good lift, and the N1 cams are just awesome, and are currently the cams used in the Mazworx S15 drag car.
Geno750 is offline   Reply With Quote
Old 09-19-2008, 12:05 AM   #6
punkrico
punkrico is on the path to ruinpunkrico is on the path to ruin
id like to hear more about this swap where else can you find info on it
punkrico is offline   Reply With Quote
Old 09-19-2008, 12:56 AM   #7
Geno750
I was considering it myself, but the biggest hangup I had was custom exhaust manifold would have to be made (the exhaust ports are huge on the VE head, requiring a different manifold), as well as a custom intake manifold, as the VE's will face backwards. You also have to run a oil feed to the head a-la LS/VTEC style. For more information you're better off just emailing mazworx. The basic breakdown of what you need to do for the swap is:
Standalone ECU (required for hall-effect sensor) I know the AEM EMS, and Haltech E8 can do this, Power FC's can't
Hall-effect sensor mod (mazworx can explain this better)
Oil feed/blockoff
Exhaust manifold
Intake manifold
Depending on the turbo you're running, you'd be better off using a SR20VE head on a smaller turbo, and a SR16VE head if running a larger. There is more overlap in the 16VE, as well as more lift, or if running a big ass turbo, you could use the N1 cams in either motor.
Supertech valve springs for the DE don't work in the VE, but from what I've gathered, H22A valve springs will work.
Thats about all I know really.
Old 09-24-2008, 08:42 PM   #8
l8nightjay
l8nightjay's Avatar
l8nightjay is on the path to ruinl8nightjay is on the path to ruin
Yeah I've been looking into this monstrous project for way to long now also. this is basically what I've gathered correct me if I'm wrong or you know better.
Head mounts up to block, but cas hits firewall. bang it out , or custom cut and weld a notch.
gotta drill head between 3 and 4th exhaust runners for oil intake if I remember correctly
as for manifolds U can us a low port s14 intake manifold ( so the intake faces the front, not the rear of the car), but u should also port mani to take benefits of increased flow from the new head, and to better match ports. or just cut all the runners off stocker, flip intake and re-weld.
full-race has a exhaust manifold for the sr20ve, there u go if you got the coin. if u dont shit u shouldn't being doing the swap anyways. a nice twin scroll gt3076 external wastage would be a nice combo. but thats all personall choice there...
and then your computer needs a update, standalone, greddy emanage ultimate... idk something to run this sweet as bitch...
alot of custom work and pretty pennies spent. check or sr20forum I think for more, (sorry I know I'm a whore, I get around .lol)
l8nightjay is offline   Reply With Quote
Old 09-26-2008, 10:43 AM   #9
punkrico
thanx im goin email mazworx and find out some more on it. Ill let you know what i find out
Old 09-30-2008, 06:44 PM   #10
socal_kouki
Just wanted to take the time to show the difference in quality when it comes to forum members addressing relevant subjects.
(Inferior, irrelevant posts.)
Oil feed/blockoff
Exhaust manifold
Intake manifold
(Helpfull, relevant post that addresses the inquiry at hand.)
Thanks Geno, good looking out.
Old 10-02-2008, 12:58 PM   #11
Geno750
Your welcome, good luck if your going to tackle this project. I wish I just took the plunge and sold my apexi turbo setup and bought a VE motor instead of building up the DE head that I have.
Old 10-05-2008, 02:17 AM   #12
Yellow4g63
Yellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of light
Send a message via AIM to Yellow4g63
I'm planning on doing this, just not sure when lol. I'm going to prob pound out the firewall a little so the SR20VE 20V Cas will clear.
Part Number:23731-8H600- Description:CAMSHAFT POSITION SENSOR
Not sure if would have to switch the CAS disk out of the RWD to make it jell with the DET ecu or not. You could use the factory lower intake manifold and make a new plenum. I'm trying to get this to work with the stock ecu to save $$$ lol.
95 240sx RB20 415whp
91 Nx2000 VVL yo
Yellow4g63 is offline   Reply With Quote
Old 04-27-2009, 10:14 PM   #13
racer98
racer98's Avatar
Trader Rating: (128)
racer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant future
Feedback Score: 128 reviews
Send a message via AIM to racer98 Send a message via MSN to racer98
and then ?
racer98 is offline   Reply With Quote
Old 04-29-2009, 03:33 PM   #14
Monooxide
Monooxide's Avatar
Monooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to behold
You will not find a SR20VET head/engine.
You'll need to get an SR20VE head.
Search harder you'll find your answer. Some things deserve to be hard to obtain.
HINT: Check some more SR oriented forums.
Monooxide is offline   Reply With Quote
Old 04-29-2009, 04:17 PM   #15
Somnambulist
Somnambulist's Avatar
Somnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfection
Send a message via AIM to Somnambulist
http://www.freshalloy.com/forums/sho...d.php?t=192893
Somnambulist is offline   Reply With Quote
