Old 04-29-2009, 07:21 PM   #1
Addicted2Kouki
Addicted2Kouki's Avatar
Addicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfection
Misfire, Backfire, Popcorn?!
So, I have been trying to figure out this problem for about a week now...
My KA-T keeps misfiring and backfiring.
Here's what happened.
I was driving on the freeway,
my spark plug wire falls off the distributor.
All of a sudden anytime I accelerate more than just cruising speed,
my car backfires constantly like popcorn and loud.
As loud as... say, FormulaD or D1 cars,
except almost as if im bouncing off the limiter but I'm not.
I drive another 2 miles to the exit and as I stop I realize my car sounds like an STI.
I figure..."great, 3 cylinders. What did I do now?"
I park in a parking lot to find the spark plug wire off the distributor.
So I plug it back up and start my car.
To my surprise it starts to misfire on idle.
lil pops here and there every couple of seconds or so.
I rev it and it misfires more.
I think its a spark plug wire I pulled that broke apart.
So I fix it, replace it with another one.
Problem is still there.
Replace spark plugs with new ones.
Idle and revving got smoother but still misfired.
Replaced cap and rotor with brand new OEM parts.
Idle and revving got even smoother but still slight misfire on hard revving.
Took it for a test drive.
On hard acceleration [anything more than somewhere between 1/4-1/2 throttle] the car backfires LOUD and constantly.
I dont know what else to check because I have already checked
spark plugs
injectors
spark plug wires
distributor cap and rotor
SOMEONE PLEASE POINT ME IN THE RIGHT DIRECTION.
Originally Posted by coreansurfer View Post
zenki's are for poors and lames
with the exception of norm who is big ballin
FS:CUSCO,GREDDY,KA-Tparts
Addicted2Kouki is offline   Reply With Quote
Old 04-29-2009, 10:34 PM   #2
norcal_black240
norcal_black240's Avatar
norcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud of
Send a message via AIM to norcal_black240 Send a message via MSN to norcal_black240
list your setup, should help out a little bit if you do.
norcal_black240 is offline   Reply With Quote
Old 04-29-2009, 10:59 PM   #3
projectslider
projectslider is an unknown quantity at this point
have you checked gapping on the plugs?
maybe your blowing the hell out of your spark!!
good luck with it!!
cheers
projectslider is offline   Reply With Quote
Old 04-29-2009, 11:02 PM   #4
[w]hite[r]abbit[x]
[w]hite[r]abbit[x] will become famous soon enough[w]hite[r]abbit[x] will become famous soon enough[w]hite[r]abbit[x] will become famous soon enough[w]hite[r]abbit[x] will become famous soon enough
+1 on the spark plug gaps. I would try .028 for the gap. Try using higher grade gasoline. Maybe that will make the car run smoother.
[w]hite[r]abbit[x] is offline   Reply With Quote
Old 04-29-2009, 11:33 PM   #5
Killa_D
Killa_D's Avatar
Trader Rating: (39)
Killa_D can only hope to improve
Feedback Score: 39 reviews
maybe bad injector or bad or dirty air control valve
Killa_D is offline   Reply With Quote
Old 04-30-2009, 12:07 PM   #6
Addicted2Kouki
Setup is
GT28R
370cc injectors
N60 maf
z32 fuel filter
s15 fuel pump
chipped ECU
the gapping is what it always has been since i went KA-T.
I use 91 octane.
ECU is tuned for this fuel and if I wanted anything higher than 91 the drive is not fun.
Im thinking i blew out my internal coil for my distributor.
Ill see.
Im also gonna check out my maf and ecu and swap them with a friends.
Old 04-30-2009, 12:13 PM   #7
WagDatto
WagDatto's Avatar
WagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfection
Send a message via AIM to WagDatto
I'd toss a timing gun at it while you're in there... I know when we first got my car to start it was about 20* advanced over stock, and would give a big backfire every 5 seconds at idle. No sense in not checking, just in case, yeah?
http://garagezoku.blogspot.com
WagDatto is offline   Reply With Quote
Old 04-30-2009, 10:07 PM   #8
essforteen
essforteen's Avatar
Trader Rating: (50)
essforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant future
Feedback Score: 50 reviews
change the dizzy that sounds like its the issue!
essforteen is offline   Reply With Quote
Old 04-30-2009, 10:25 PM   #9
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
Do a Leak Down Test. Perhaps you have a burnt exhaust valve.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
