Old 04-29-2009, 11:47 PM   #1
BeauS13
BeauS13's Avatar
BeauS13 is an unknown quantity at this point
Send a message via AIM to BeauS13
DIY on turbo install????
does anyone have a DIY on a turbo install?? im about to put a s15 turbo on my sr20det i have all adapters and everything
(noobie Q)
should i use thread lock? and gasket sealer?
thanks
BeauS13 is offline   Reply With Quote
Old 04-30-2009, 12:26 AM   #2
waynehead05
waynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura about
Send a message via AIM to waynehead05
I used 2 new gaskets, and no thread locker.
Who in their right mind would want to lead this nation of Me-First Right-Now Do Nothings??
waynehead05 is offline   Reply With Quote
Old 04-30-2009, 06:10 AM   #3
Sileighty_85
Sileighty_85's Avatar
Search
there are 3 or 4 threads on here about installs on the GT2871R
I know you said S15 turbo.
Exact same principle
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 04-30-2009, 10:06 AM   #4
singlecamslam
singlecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymore
Technical Articles: SR20 Bottom Mount Turbo Manifold Install
pretty much all you need there.
Nothing says racecar like a stock car with no interior.
singlecamslam is offline   Reply With Quote
Old 04-30-2009, 02:03 PM   #5
sbanzer123
sbanzer123's Avatar
sbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the rough
if you go out and look at your car you can figure it out, its really not that difficult.
sbanzer123 is offline   Reply With Quote
Old 04-30-2009, 03:15 PM   #6
jspaeth
jspaeth's Avatar
One tip of advice would be to put the oil and coolant lines on the turbo first, before attaching the turbo to manifold, and then manifold to head.
And make sure you have them tightened and pointing in the right direction.
I put on a stainless steel line into the top of the turbo, and after putting everything together and starting her up, oil leaked out of that line (it was faulty, i got a free replacement).........but it's almost IMPOSSIBLE to get to that line with the turbo on the car. so get those lines taken care of first.
Daily driven
