Old 04-28-2009, 10:56 AM   #1
Croan
Croan is just really niceCroan is just really niceCroan is just really niceCroan is just really niceCroan is just really niceCroan is just really niceCroan is just really niceCroan is just really nice
Question Megan faulty test pipe??
Ill try to make this short as poss. I have a blitz down pipe>Megan test pipe>BC spec II cat back. The exhaust fits. i saw it on another car. But when i installed it on to my car, the flange holes from the test pipe to the BC are off by about an inch. so to install it i had to rotate the BC to line up with the holes, bolt it down, an then hang it. But it only makes one hanger, has no N1 angle and rubs my diff. My Q is, could this result from mix of manufactures? What do u think caused this?
Any help would be greatly appreciated!
Croan is offline   Reply With Quote
Old 04-28-2009, 12:57 PM   #2
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
Rotated off by an inch? or seperated.
Usually the test pipe is the issue, I had to try 2 different types because the size of the flanges.
its your test pipe, check to see if the rear flange is clocked correctly.
Bigsyke is offline   Reply With Quote
Old 04-28-2009, 01:08 PM   #3
georgesal
georgesal's Avatar
georgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to behold
you coupld have intalled it backwards
georgesal is offline   Reply With Quote
Old 04-28-2009, 01:12 PM   #4
xs240
xs240 is an unknown quantity at this point
Rotflmao, I had to come into this thread. Only Megan Racing, could screw up a testpipe. If anybody could
xs240 is offline   Reply With Quote
Old 04-28-2009, 02:07 PM   #5
Croan
the test pipe hole and BC hole do not line up. is it possible to have it back words??? thanks for the help guys
Old 04-28-2009, 02:08 PM   #6
smelly240
smelly240's Avatar
YOU BOLTED IT IN BACKWARDS. LIKE REALLY YOU DID.
funny
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
Old 04-28-2009, 02:11 PM   #7
Bigsyke
Bigsyke's Avatar
or she has to rotate it 180*
Old 04-28-2009, 02:37 PM   #8
Croan
are u guys joking?
Old 04-28-2009, 02:42 PM   #9
Enna
Enna will become famous soon enoughEnna will become famous soon enoughEnna will become famous soon enough
Send a message via AIM to Enna Send a message via MSN to Enna
They probably aren't. I've had bad experiences with their shit, hence why I don't buy it.
I half expected this to be a thread about it breaking welds or something...
Originally Posted by soreballz View Post
I hoped the candy would make it delicious, but I was incorrect.
Enna is offline   Reply With Quote
Old 04-28-2009, 02:53 PM   #10
Croan
i just called Megan. They said it could be flipped or could not be. soooooooo i looked at pics of it and its identical when u flip it.....????????
Old 04-28-2009, 05:30 PM   #11
Bigsyke
Bigsyke's Avatar
umm, with the symtoms your discribing you should be able to flip it. I have the same pipe. Both flanges are clocked.
Why dont you get under the car and either flip it, or rotate it 180*
Old 04-28-2009, 11:51 PM   #12
WERDdabuilder
WERDdabuilder's Avatar
go under, flip it/rotate and im sure it will fit.
When the power of love overcomes the love of power, the world will know peace
Old 04-29-2009, 10:35 PM   #13
norcal_black240
norcal_black240's Avatar
norcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud of
Send a message via AIM to norcal_black240 Send a message via MSN to norcal_black240
My megan test pipe sucked, I had to chop off the flange and reweld it to make it fit properly.
norcal_black240 is offline   Reply With Quote
Old 04-29-2009, 11:19 PM   #14
memo92
memo92's Avatar
memo92 is close to perfectionmemo92 is close to perfectionmemo92 is close to perfectionmemo92 is close to perfectionmemo92 is close to perfectionmemo92 is close to perfectionmemo92 is close to perfectionmemo92 is close to perfectionmemo92 is close to perfectionmemo92 is close to perfectionmemo92 is close to perfection
Yeah I think the test pipe just won't line-up.
I bought a used Magan 2.5" TestPipe and It was hard to fit. I flipped it front to back and did the 180 twist and nada. I have stock headers/downpipe with a 2.5" RSR cat-back exhaust system. When I finally bolted it up to a good enough fit it totally shifted the RSR exhaust system high and against my car's hangers.
(I think I have the side of the testpipe with the magan badge facing up and is bolted towards the headers/engine end of the car.)
Right now I think the TestPipes welds may have broken. The reason is that when I roll down my window while driving I get heavy exhaust gases comming into my car's cabin. I am also getting a loud rattle from my exhaust system at high RPMs, so I think the Magan is broken.
I'm not in a hurry to check, though, because my car is pretty low.
Bottom line is that the Magan test pipe was not manufactured to the proper specs. You may have to have someone cut the flange and weld it like one of the fellows in a previous post stated.
L8er!
memo92 is offline   Reply With Quote
Old 04-30-2009, 12:41 AM   #15
Somnambulist
Somnambulist's Avatar
Somnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfectionSomnambulist is close to perfection
Send a message via AIM to Somnambulist
MR test pipe bolted up just fine on my S14... Of course I had the MR three inch downpipe and MR Drift Spec catback as well.
Somnambulist is offline   Reply With Quote
Old 04-30-2009, 12:54 AM   #16
BlitzRPS13
BlitzRPS13's Avatar
BlitzRPS13 has a little shameless behavior in the past
My MR test pipe fit perfect. Not saying i like any of megans products.. but this was the only really available option. But yea.. fits fine on my car and my gf's car.
BlitzRPS13 is offline   Reply With Quote
Old 04-30-2009, 01:02 AM   #17
memo92
memo92's Avatar
Yeah, my 240 is an S13, though.
Your equipment is all MR, so it had to line-up.
Are your 240s S13 or S14?
Or is there a difference?
Maybe mine was meant to go on an S14. IDK I bought it used. The guy I bought it from had an S13. The only thing he didn't like about it was that he said it made his car use-up more fuel.
If I replace my MP then I'll just try another brand's test pipe.
Old 04-30-2009, 10:13 PM   #18
BlitzRPS13
BlitzRPS13's Avatar
My silvia and her 180sx.. not 240's.. but yea.. both s13's.. both worked fine.
Old 04-30-2009, 10:24 PM   #19
Almedarj
Almedarj's Avatar
Almedarj is an unknown quantity at this point
Send a message via MSN to Almedarj
i've never had a problem with anything from megan maybe i'm just lucky but you should really get under your car an filp the test pipe and or rotate it 180 because i have a megan 3in test pipe and apexi n1 and it fits great and i've used my buddies bc spec 2 and didn't have an issue with it either
Almedarj is offline   Reply With Quote
