Old 05-02-2009, 07:43 AM   #1
RacerX1
RacerX1's Avatar
RacerX1 is an unknown quantity at this point
Battery question
I relocated my battery to the trunk in my S13 and I am running 1gauge wire to the front of the car and I want to use a splitter and run two 4 gauge wires-one to the fuse box and one to the starter. I dont know jack about electronics or amps/fuses etc so I need to know which fuse type to go with...heres what Im lookin at
http://www.knukonceptz.com/productDe...?prodID=KNF-12
RacerX1 is offline   Reply With Quote
Old 05-03-2009, 06:44 PM   #2
KoukiMonsta
KoukiMonsta's Avatar
KoukiMonsta is a well-known jackass
ya that will work you can use any distribution block, just mount it in the bay somewere and run your wires to fuse box/starter
KoukiMonsta is offline   Reply With Quote
Old 05-03-2009, 07:17 PM   #3
RacerX1
RacerX1's Avatar
It gives me 2 options for amps, from 30A- 150A...which should I go with?
Old 05-03-2009, 07:51 PM   #4
KoukiMonsta
well you can go with something that doesnt have a fuse like this StreetWires DBX3434 3-way power distribution block — 4-gauge inputs and outputs at Crutchfield.com
im not sure how many amps you would need for the fuses though sorry man.
Old 05-03-2009, 09:33 PM   #5
RacerX1
RacerX1's Avatar
Its all good, I did some more research and Im goin with 150A fuses
Old 05-12-2009, 06:55 PM   #6
alkemyst
alkemyst's Avatar
alkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nice
Send a message via AIM to alkemyst
I ran 1/0 and got this from sounddomain when they were blowing them out StreetWires Combo AGU Fused Distribution Block 4-way/4-gauge at Crutchfield.com
Keep in mind you should fuse up and downline from the battery for the main line 150a may be ok...I run 200a...at the block I break it out for whatever I am running downstream.
Now my Kensai, I curse you to be a Ronin and with the my remaining spirit I, beseech Chimata-No-Kami, to have you wander through time and distance lands, seeking a new master.
alkemyst is offline   Reply With Quote
Old 05-12-2009, 06:58 PM   #7
junbugs13
junbugs13's Avatar
junbugs13 is an unknown quantity at this point
roll with the 150a cuz the starter is goin to pull alot of amps when you crank the engine
junbugs13 is offline   Reply With Quote
