Old 10-14-2010, 01:18 AM   #1
Osmar
Osmar is an unknown quantity at this point
My 240 sounds like wrx
It wont run properly
cilinder #3 ist firing
i took the wires out 1 at the
time while car was runing
and #3 cilinder won't do anything.
it comes and goes even when
im in the high way. some times
it just loses power and sounds
like wrx
Osmar is offline   Reply With Quote
Old 10-14-2010, 01:19 AM   #2
ILoveMyRHS13
ILoveMyRHS13's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
Good work, Copernicus.
Make sure it's getting fuel AND spark to all 4 cylinders.
Old 10-14-2010, 01:25 AM   #3
theslows13
theslows13 will become famous soon enoughtheslows13 will become famous soon enoughtheslows13 will become famous soon enough
bad injector. callin it now
when you pulled #3 wire, was it still tryin to arc to the plug as you removed it? if so, you got spark.
theslows13 is offline   Reply With Quote
Old 10-14-2010, 01:26 AM   #4
jdmjap808
jdmjap808's Avatar
jdmjap808 is an unknown quantity at this point
change your fuel filter and flush out or buy new injectors.. Oh add some sea foam, it should help out a bit
jdmjap808 is offline   Reply With Quote
Old 10-14-2010, 01:27 AM   #5
ChiSleepyEyes
ChiSleepyEyes's Avatar
ChiSleepyEyes is an unknown quantity at this point
Send a message via AIM to ChiSleepyEyes
Injector hands down
ChiSleepyEyes is offline   Reply With Quote
Old 10-14-2010, 01:28 AM   #6
ILoveMyRHS13
Trader Rating: (25)
Yup, my car killed injector #3 last year. It's a common problem.
Old 10-14-2010, 01:32 AM   #7
Osmar
I took the wire of cilinder#3 an it
was runing the same
Old 10-14-2010, 01:48 AM   #8
Ph0king
Ph0king's Avatar
Ph0king is an unknown quantity at this point
its probably your Distributor rotor and cap. That was the source of my problem when I had that.
hello.
Ph0king is offline   Reply With Quote
Old 10-14-2010, 01:52 AM   #9
S13project
S13project's Avatar
S13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of light
when i got the boxer sound it was due to a wire backing out of one of the injector plugs. re-pinned that wire and ran clean
S13project is offline   Reply With Quote
Old 10-14-2010, 01:59 AM   #10
chetacheese
chetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of light
Send a message via AIM to chetacheese
injector
+1
chetacheese is offline   Reply With Quote
Old 10-14-2010, 04:38 PM   #11
Perfect Balance
Perfect Balance's Avatar
Perfect Balance is an unknown quantity at this point
I'm going with injector as well. Had to replace mine last year as well.
Perfect Balance is offline   Reply With Quote
Old 10-14-2010, 04:42 PM   #12
besTint
Trader Rating: (81)
besTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the rough
Feedback Score: 81 reviews
Send a message via AIM to besTint
is this a SR? KA? if it's a SR, i say bad coilpack.
http://squarespokes.com/
besTint is offline   Reply With Quote
Old 10-14-2010, 04:55 PM   #13
slomar91
slomar91 is an unknown quantity at this point
I'm assuming its KA since he said he pulled spark plug wires. Possibilities: spark plugs, spark plug wires, fuel injector, or a problem i personally experienced: fuel injector harness. Try wiggling the clip that goes to that injector while its running and if the idles jumps it could be that. Take the clip off and inspect it for any corrosion or a burnt look
slomar91 is offline   Reply With Quote
Old 10-14-2010, 06:30 PM   #14
Marcus
Marcus's Avatar
Trader Rating: (18)
Marcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfection
Feedback Score: 18 reviews
check to see if the spark plugs are all the way in
Marcus is offline   Reply With Quote
Old 10-14-2010, 06:37 PM   #15
zylvia213
zylvia213's Avatar
Trader Rating: (36)
zylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond repute
Feedback Score: 36 reviews
Send a message via AIM to zylvia213
I say injector too...
zylvia213 is offline   Reply With Quote
Old 10-15-2010, 08:24 AM   #16
SR20Driftking4lyf
SR20Driftking4lyf's Avatar
SR20Driftking4lyf is an unknown quantity at this point
I had a similar problem prior to doing my swap and had a bad injector on the KA, I would start there for sure.
SR20Driftking4lyf is offline   Reply With Quote
Old 10-15-2010, 08:38 AM   #17
ElmStormer
ElmStormer is an unknown quantity at this point
Going with injector also.
ElmStormer is offline   Reply With Quote
Old 10-15-2010, 09:17 AM   #18
240sx123$
240sx123$ is an unknown quantity at this point
One more vote for injector here.
If not that, then its definitely the muffler bearings.
240sx123$ is offline   Reply With Quote
Old 10-15-2010, 01:31 PM   #19
iamtheyi
iamtheyi's Avatar
iamtheyi is an unknown quantity at this point
lol most people that have this problem it's caues of the injector.
iamtheyi is offline   Reply With Quote
Old 10-15-2010, 10:39 PM   #20
kalypso123
(ノಠ益ಠ)ノ彡
could be a loose or damaged MAF wire.
but bad injector or coil pack sounds right.
:0)
Old 10-15-2010, 11:18 PM   #21
Mangudai
Mangudai's Avatar
Mangudai is an unknown quantity at this point
You could test injector #3 with a multimeter on ohms or get a long screwdriver and put the metal end directly on the injector and listen to see if you can hear it cycling.
Almost there.
Mangudai is offline   Reply With Quote
Old 10-15-2010, 11:24 PM   #22
lflkajfj12123
#3 injector
super common problem
had to do it twice in 6 months
Old 10-15-2010, 11:27 PM   #23
locoluna825
locoluna825's Avatar
locoluna825 is an unknown quantity at this point
^ With him on that one. Try a Noid Light. Ka hanresses connectors like to rot out and turn green. I wilgled my connectors on the injectors and would affect the idle. I had to buy all new EV1 style connectors and solder them into my harness to get rid of that. Now im having trouble with one of my exhuast camshaft rockers. when The hydrolic tappet smashes down on me, The car sounds just like a "WRX" lol
locoluna825 is offline   Reply With Quote
Old 10-15-2010, 11:34 PM   #24
speedracer2169
speedracer2169's Avatar
speedracer2169 is an unknown quantity at this point
I'm having a very similar issue. It usually only does it when there is a lot of moisture in the air like when it rains. I can smell gas coming out of the exhaust while it's misfiring so I'm assuming its an ignition or maf problem or maybe egr but I havent had time to diagnose let alone where to start. Any ideas?
speedracer2169 is offline   Reply With Quote
Old 10-15-2010, 11:35 PM   #25
omgRWDgoodness!
omgRWDgoodness!'s Avatar
Trader Rating: (48)
omgRWDgoodness! is an unknown quantity at this point
Feedback Score: 48 reviews
Or maybe he's just ***king with all of us and secretly has an EJ in there...
omgRWDgoodness! is offline   Reply With Quote
Old 10-15-2010, 11:45 PM   #26
1jz_240
1jz_240 is an unknown quantity at this point
im having the same problem! except mine is on #4. does it matter which one? because it did it most of the day and then BAM it started working fine again. injector?
1jz_240 is offline   Reply With Quote
Old 10-16-2010, 12:21 AM   #27
locoluna825
^either that or its the harness.
Old 10-16-2010, 12:57 AM   #28
Mangudai
Mangudai's Avatar
Didnt know this was such a common problem? Or maybe its because these cars are getting older and older..not sure. I think one of mine is stuck open as my fuel economy is in the toilet but I'll be taking care of that soon.
Almost there.
Old 10-16-2010, 02:36 AM   #29
rob22
rob22's Avatar
Trader Rating: (50)
rob22 is an unknown quantity at this point
Feedback Score: 50 reviews
i hate ka injectors..
wtb s14 roof wing/spoiler! pm me
rob22 is offline   Reply With Quote
Old 10-16-2010, 03:37 AM   #30
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
many of you guys are saying bad injector, but what about bad injector o-rings? mine failed and sounded like a wrx as well
S-Nation S13 is offline   Reply With Quote
