Old 03-26-2003, 03:52 PM   #1
Crab Spirits
Crab Spirits is an unknown quantity at this point
Send a message via AIM to Crab Spirits
s13 Silvia transmissions
Probly a noob question, but I've seen a lot of conflicting info on this.
Is there a USDM counterpart for the S13 Silvia 5-spd trans? Will a 240sx unit work? What are the differences?
JDM fun
Crab Spirits is offline   Reply With Quote
Old 03-26-2003, 04:02 PM   #2
The Mole
The Mole's Avatar
The Mole is an unknown quantity at this point
Send a message via AIM to The Mole
i believe you have to swap the bell housings from what ive been told
-chris
p.s. possibly a noob answer too lol
The Mole is offline   Reply With Quote
Old 03-26-2003, 04:10 PM   #3
Crab Spirits
I have heard that too, but is a 240 trans the same trans? Will it turn a silvia driveshaft?
JDM fun
Old 03-26-2003, 04:43 PM   #4
RedSuns
RedSuns's Avatar
RedSuns is an unknown quantity at this point
Send a message via AIM to RedSuns
the KA and SR tranny are two peice trannys......once you have swapped the bell housing they will match up directly....both the S13/S14 SR tranny will work with the KA(USDM 240SX) driveshaft.....but the S15 tranny requires the front driveshaft from a S15....the S15 has different splines that the S13/S14 SR
Johnathan
2005 Titan
1996 240SX
1991 240SX
1974 260Z
1996 Honda CBR 600 F3
RedSuns is offline   Reply With Quote
Old 03-26-2003, 05:37 PM   #5
SimpleS14
SimpleS14's Avatar
So you can use a KA tranny with a S13/14 SR?
Goals are dreams with a deadline.
L.H.O.O.Q.
SimpleS14 is offline   Reply With Quote
Old 03-26-2003, 05:56 PM   #6
Dousan_PG
Dousan_PG's Avatar
Yes.
Aaron
Pink GodziRa
Old 03-26-2003, 06:01 PM   #7
Dark
Dark's Avatar
Dark is an unknown quantity at this point
Is the JDM SR tranny better than the USDM cause I'm not happy with mine or are they exactly the same
93 Fastback, 5spd with obx shortshifter
Power is in the control of strength.
Dark is offline   Reply With Quote
Old 03-26-2003, 06:14 PM   #8
RedSuns
RedSuns's Avatar
the internal gearing of the SR is different that the gearing of the KA......i will post te differences once i find them
Johnathan
2005 Titan
1996 240SX
1991 240SX
1974 260Z
Old 03-26-2003, 07:16 PM   #9
Jim96SC2
Jim96SC2 is an unknown quantity at this point
Send a message via AIM to Jim96SC2
I believe that the silvia tranny has double synchomesh also.
Swap DONE: 40K Redtop, Greddy Turbo extension, Greddy DP, Greddy V-SPL FMIC, Greddy Hotpipe, HKS SSQV, Koyo Radiator, Toda Ultralight FW, Spec Stage 2 Clutch, ATS 2-way Diff., Rice-Boy Red Air Filter.
Jim96SC2 is offline   Reply With Quote
Old 03-26-2003, 09:35 PM   #10
Dark
Dark's Avatar
Ok if it does have double synchromesh does that mean that shifting will be much smoother everytime my gear grinds I remeber my freinds VR4 ahhh that was a sweet tranny
Old 03-27-2003, 03:14 AM   #11
DuffMan
DuffMan's Avatar
No the gear ratios are the same. CA18 has different gear ratios though.
Kind of weird actually, the USDM 240sx had silvia/180sx gear ratios before the silvia/180sx got them.
Old 03-27-2003, 07:11 AM   #12
Steeles
Steeles's Avatar
Steeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura about
Send a message via AIM to Steeles Send a message via Yahoo to Steeles
ratios are the same EXCEPT 5th gear (uiuc will correct me cuz he's a nerd like that) but the KA is like .752 and the SR is like .856
different front bellhousings as said before but both work quite well
Keeping it Godzira bishes.
So I murdered another turbo
Steeles is offline   Reply With Quote
Old 03-27-2003, 09:24 AM   #13
N1ceDrgn
N1ceDrgn's Avatar
N1ceDrgn is an unknown quantity at this point
Send a message via MSN to N1ceDrgn Send a message via Yahoo to N1ceDrgn
The transmission core's or gear sets are the same. Now whether or not the transmission housings, when you start to swap them in and out will match up I can't say. With mine I had to keep the entire housing to get things to work. Otherwise I'd have to make some changes to my driveshaft. But there are differences in the gears. Both SR and CA from what I have learned are different from the KA transmissions. The differences come into play in the top end or final gears. After changing out my CA transmission core, I haven't been too happy with the KA gear set I am using. I am in the process of acuiring the CA gears and bearings I need to rebuild my original gear set. Back to the subject though, the main differences are in the final gears. As far as mounting, changing out the bell housings should work.
..working on something that is slowly getting built up and restored..
N1ceDrgn is offline   Reply With Quote
Old 03-27-2003, 05:15 PM   #14
Crab Spirits
See what Imean by conflicting info?
JDM fun
Old 04-01-2003, 09:44 PM   #15
the head
the head's Avatar
if you swap the bellhousings it will fit
IIRC the first three gears on SR trans have double synchros
i am not aware of any other i don't know gear ratios so i am not saying for sure on that
