Old 01-06-2009, 06:39 PM   #1
jeb1517
jeb1517's Avatar
jeb1517 is an unknown quantity at this point
s13 coupe silvia front doesn't line up
I recently...acquired...an s13 that already had the silvia front end on it. The only gay part is that on the driver's side, the hood sits lower than the fender, maybe half an inch I would say right by the headlight (the difference gets less as you go towards the windshield obviously). I don't know if it's noticable to the average person but it annoys the F%*@ out of me.
I read about some installs and it doesn't seem like that difficult of a swap. Could there be a bracket or something missing? Should I take it apart and refit it? Or maybe its as simple as just re-fitting the hood? Any thoughts or suggestions would be appreciated. I'll try to get pics up soon.
jeb1517 is offline   Reply With Quote
Old 01-06-2009, 07:40 PM   #2
alzahakar
alzahakar's Avatar
alzahakar has a little shameless behavior in the past
Make sure the hood stops are there/adjusted correctly.
alzahakar is offline   Reply With Quote
Old 01-07-2009, 06:43 PM   #3
4x4le
4x4le's Avatar
4x4le is an unknown quantity at this point
Send a message via AIM to 4x4le Send a message via Yahoo to 4x4le
^^yep, I removed my hood stoppers and put in hood pins, but they searve the same principal if they are properly adjustible.
Another thing you can do is remove the fender and bend the lip that bolts to the car up just a little and then test fit the fender again.
4x4le is offline   Reply With Quote
Old 01-09-2009, 01:02 PM   #4
redsx13
redsx13's Avatar
redsx13 is an unknown quantity at this point
+1, check you stops
redsx13 is offline   Reply With Quote
Old 01-21-2009, 04:28 PM   #5
jeb1517
jeb1517's Avatar
Sorry this took so long but anyways...haven't had a chance to check the hood stops but just wanted to post the pics up, i guess there's no reason for the pics anymore but since i took em i figured might as well post em. I'll post back after i get a chance to check the stops but chicago weather has been really gay lately n school is not helping either...thanks for the replies though
Old 05-24-2009, 05:31 PM   #6
jon_mr2
jon_mr2 has a reputation beyond reputejon_mr2 has a reputation beyond reputejon_mr2 has a reputation beyond reputejon_mr2 has a reputation beyond reputejon_mr2 has a reputation beyond reputejon_mr2 has a reputation beyond reputejon_mr2 has a reputation beyond reputejon_mr2 has a reputation beyond reputejon_mr2 has a reputation beyond reputejon_mr2 has a reputation beyond reputejon_mr2 has a reputation beyond repute
if not the hood stops, check your hood hinge. the one 240 i am working on was rusted and the hood hinge started to seize and never really worked good. so, when i opened the hood, the hinge would bend at the bracket and cause the hinge to be warped... it eventually broke, lol. but now i got some new ones. hope you figure it out.
jon_mr2 is offline   Reply With Quote
