Old 04-02-2003, 11:56 AM   #1
bmarley5780
bmarley5780 is an unknown quantity at this point
valve problems
I am thinking about gettting a 240 '93, but there is a engine ticking, knocking. In the head. It sould like a bad valve. How much would it cost me to fix? If I fix it how much would the materials be?
Thanks
bmarley5780 is offline   Reply With Quote
Old 04-02-2003, 12:19 PM   #2
thelinja
thelinja's Avatar
thelinja is making a name for him/her selfthelinja is making a name for him/her self
Where is the tapping coming from? The front of the head? If so, it's probably just the front timing chain guide. This is a fixable problem on a lot of 240's. Just take off the valve cover, remove the guide, get a new valve cover gasket, and bolt the cover back on, make sure you have a torque wrench so you don't over torque the bolts. Go ahead and do a search too, there are several topics like this.
thelinja is offline   Reply With Quote
Old 04-02-2003, 10:04 PM   #3
sykikchimp
WOW addicted
sykikchimp's Avatar
if you have a long screw driver, you can put your ear on the handle, and the tip on the engine, and use it as a stethescope to determine Where the noise is comming from.
Like Linja said.. front cover = timing chain, anywhere around valve train = lifter tick.
