Old 07-11-2009, 02:45 AM   #1
Zenki_Kouki.5
Zenki_Kouki.5 is an unknown quantity at this point
Fuck coolant leaking again
Well i replaced my water pump and it still leaks.
i resealed the shit whre the thermostat goes in
and it still leaks
i found where its leaking from and its the bolt rite next to the thermostat
Zenki_Kouki.5 is offline   Reply With Quote
Old 07-11-2009, 02:52 AM   #2
ILoveJDM
ILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to behold
awesome!!
now go fix it
ILoveJDM is offline   Reply With Quote
Old 07-11-2009, 08:53 AM   #3
heavenboundkevin
heavenboundkevin's Avatar
heavenboundkevin is an unknown quantity at this point
^ lol, you might want to see if the thermo housing is sitting flush where it mounts to the engine. Maybe theres a washer on that bolt or something? Also something MIGHT have warped, because im guessing you swapped thermos/water pump cause you overheated?
Originally Posted by rat240 View Post
sick bro .... hella jdm foshow i love haters
heavenboundkevin is offline   Reply With Quote
Old 07-11-2009, 08:59 AM   #4
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
thermo housing hm..rtv make sure everything sits flush theres no point in slapping on a new part and the housings all eff up to where it dosent seal up at that point no matter what new part you put youll always have a leak!!
S-Nation S13 is offline   Reply With Quote
Old 07-11-2009, 09:10 AM   #5
FRoSt415
FRoSt415's Avatar
FRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura about
Send a message via AIM to FRoSt415
after installing a water pump u are supposed to pressure test it. if u found where it is leaking reseal it and don't just glob on the ATV please, not saying u did but there are proper ways to do things and if u don't do them problems can occur. Also u can slap a little ATV on the bolt if u want. Try it out shouldn't take more then 30 mins and report back
FRoSt415 is offline   Reply With Quote
Old 07-11-2009, 04:12 PM   #6
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
if you follow the FSM way of applying the PERMATEX ULTRA GREY you will not have any leaks, even with a slightly slightly warped front cover.
Its just a user install issue.
Bigsyke is offline   Reply With Quote
