Old 04-06-2003, 08:55 PM   #1
sL103
sL103 is an unknown quantity at this point
Send a message via AIM to sL103
how much boost can stock headgaskets take?
since i did a very nice build up on a 300ZX this summer we opted not to go with a copper gasket because according to a well known source the stock head gasket could take 29lbs of boost before blowing, Does anyone know what the rb25det would take before it belows i know it has a lower compression than that of a 300ZX tt respectively at 9:1:1 i know the rb20det is at 8:1:1 is that right?? and is the rb25det at 8:5:1?? has anyone used an aftermarket headgasket like HKS/NISMO/or Power Industries??
just checking with the guys that have done the rb25det swap
thank you, Shawn
sL103 is offline   Reply With Quote
Old 04-06-2003, 09:48 PM   #2
lbcklik1486
lbcklik1486's Avatar
lbcklik1486 is an unknown quantity at this point
The rb has 9:1 also.
Your car has 4 more liters, and it's unfair to race because I have a turbo huh?
lbcklik1486 is offline   Reply With Quote
Old 04-07-2003, 12:08 AM   #3
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
Originally posted by James
Please only someone with an RB25 reply, don't speculate.
yeah, and there are SO many people here with RB25s...let alone ones with TONS of boost.
The SR stock head gasket is good for a lot of boost. It's a metal gasket. I'm sure the RB is the same. Avoiding detonation, I'm sure the RB would be good for 30-40 psi without popping. But you'll probably lift head bolts and hole pistons way before that.
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
Old 04-07-2003, 01:09 AM   #4
DuffMan
DuffMan's Avatar
Well Apex-i makes metal headgaskets for RB engines so I would try calling or emailing them, they should know. They do a lot of RB work. Also motorex could probably tell you, though i dont know if they do a lot of work on 25's.
Old 04-07-2003, 05:17 PM   #5
sL103
thanks for the info
i apperciate it
