Old 06-19-2009, 11:22 PM   #1
nrmskate
nrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura about
Clutch question
Alright, tonight I removed the tranny and all (Clutch and pressure plate) and I took out the old throwout bearing and it spun freely, but the new one, doesn't spin at all, even after a lot of grease.
Also, how do you attach the clip on the throwout bearing?
thanks in advance.
nrmskate is offline   Reply With Quote
Old 06-19-2009, 11:26 PM   #2
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
wanna explain it a little better
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 06-20-2009, 12:00 AM   #3
nrmskate
How can I explain any better.
The old one was spinning, the new one is not.
I just wanna know if the new bearing is supposed to spin (Well duh, it's a bearing), and if it's supposed to, how to get it to, or should I just use the old one.
Old 06-20-2009, 09:12 AM   #4
nrmskate
Bump, I need to get this done to go to work.
Old 06-20-2009, 09:28 AM   #5
94_240sx
94_240sx is on a distinguished road
My old OEM bearing was turning well, but I could tell it was kinda loose. Got a new OEM bearing, and it was also turning well, but it was more solid turning. Does that make sense? Anyway, sounds lke your new bearing is not good.
What do you mean by clip? You mean sleeve?
94_240sx is offline   Reply With Quote
Old 06-20-2009, 09:33 AM   #6
nrmskate
I figured the clip part out.
Would I be okay just leaving in the old TOB? It seems to spin freely, just doesn't slide on the shaft to well, but the other bearing completely doesn't spin at all.
Old 06-20-2009, 09:35 AM   #7
burnsauto
burnsauto's Avatar
if your in a jam because of work, just use the old one....but order a new one and replace it a little later.
Old 06-20-2009, 10:20 AM   #8
s13newb
s13newb's Avatar
s13newb is an unknown quantity at this point
Send a message via AIM to s13newb
use the old one for now and change it later sounds like a good tip to me ........ or get sum ballz and make the new one spin .. lol ..
s13newb is offline   Reply With Quote
Old 06-20-2009, 06:16 PM   #9
nrmskate
Alright, new delima.
I just used the TOB off my old S13 Tranny, spins freely.
Anyway, when I was taking the tranny out, I broke the CPS, I bought a new one, would I be able to stick it in after the tranny is installed so I don't break it again?
Thanks for the help peeps.
Old 06-23-2009, 12:41 PM   #10
FRoSt415
FRoSt415's Avatar
FRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura about
Send a message via AIM to FRoSt415
dont forget to grease up the pivot ball!!!
FRoSt415 is offline   Reply With Quote
Old 06-23-2009, 05:35 PM   #11
nrmskate
I already installed everything, I didn't grease anything, it was still greased from the s13 tranny.
Everything is working great!
I don't even know where the pivot ball is.
Old 06-23-2009, 06:04 PM   #12
zugoi
zugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to behold
its what your release fork sits on.
Drunk posting FTW!
zugoi is offline   Reply With Quote
