stock strut
I need a front passenger side strut, with everything. I dont need the spring but I do need the top mount. can be blown, just not damaged. thanks
pm me please closer to ky the better. will pay within reason. |
the part where it needs to bolt to the spindle the actual holes are smaller on a s13 so if you want to use s13 shocks youll have to drill it bigger or used some sleeves (real simple thing to do).
Thats the only difference? I have an s14 one on the driver side. I need the stock stuff so I can mount the konis. but dont want to be miss matched.
so would prefere an s14 strut. |
Is there any difference in the shock diameter or anything. I ordered konis for an s14, and if I cant mount them to the stock s13 struts then there is no use of them. konis are inserts btw.
