![]() Join Date: Mar 2004
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 7 reviews
Autoto Manual swap no Fuel
Ok, need a little help. I wanted to see if I had my wiring done correctly before I pulled the engine again to check for a slave cylinder leak, so I slapped on the starter and plugged in all the wires. I turn the key and the engine cranks, but I've got no fuel. The fuel pump doesn't turn on or even start priming. Am I missing something. I am doing a auto to 6 speed swap with this conversion, so I did jump the top connector next to the fuse box that was for the Auto Tranny (Neutral position I think) But am I missing something else. I swapped in a Walbro fuel pump a month or so ago, but it's never been tested or anything.
When I jump the fuel pump wire directly to the battey and hear a relay clicking in the driverside foot well. Next to the fuse box. What am I missing, sorry this is my first Auto to 5/6 speed swap as well.
LSX Kouki Project, swap completed in Dec 09 |
I think I know what the problem is. I'm looking a 2 different F3 pinouts and 1 says the 11. is Fuel Pump (FPR) and the other says 11. Fuel Pump Relay (to ECM). I think I'm just powering up the Fuel Pump relay. Anyone, know what wire on F3 the fuel pump should be wired into? Also, what is the ECCS relay for? Do I need it when running a stand alone ECU?
LSX Kouki Project, swap completed in Dec 09 Last edited by Gjohnson7; 07-15-2009 at 10:30 PM.. |
