Old 07-12-2009, 05:08 PM   #1
DMN
DMN is an unknown quantity at this point
studdering/jerking on acceleration (sr20det)
So Ive had this car for about 2 months its always studdered a bit around 2500 and i let off the gas and it smooths out, today i turned up the boost 1psi and drove it to work in the rain, it bucked at 2.5k,3k,4k ran like crap, so i turned down the boost(dont think that caused it) still the same deal, also it does not rev freely it will studder/misfire at 2.5k 3k 4k and so on, it seems to be happier in open loop than closed loop but both are not great,
I have all vaccum lines ziptied, fpr is nismo and i have a walbaro 255 fuel pump,new spark plugs a week ago gapped at .028
oh yeah it also idles fine
and it also seems to hold boost fine
Please help i dunno what it could be
DMN is offline   Reply With Quote
Old 07-12-2009, 07:12 PM   #2
ford_o
Banned from the Marketplace
ford_o is an unknown quantity at this point
check your fuel system... i had sludge built up in my tank and caused complete power loss till i cleaned it out. fuel filter mayb also!!
ford_o is offline   Reply With Quote
Old 07-12-2009, 08:52 PM   #3
wings_s13
wings_s13 is an unknown quantity at this point
I had a prob just like this and it was be my maf was loose, not off just loose. it ideled fine and all that but would not let me get above 3k rpms, so check that. if its not that then something to do with your fule system. good luck
wings_s13 is offline   Reply With Quote
Old 07-12-2009, 08:52 PM   #4
nismolism
nismolism's Avatar
nismolism is an unknown quantity at this point
try your tps sensor i had same issue when i got my swap done...im also runnin a stock fuelpump...
nismolism is offline   Reply With Quote
Old 07-13-2009, 10:46 AM   #5
DMN
Hey thanks guys im checking the TPS today, Just cleaned the maf so that wasent it, could it possibly be coil packs? it started doing it bad when it was raining i dunno if that helps or not?
Old 07-13-2009, 11:03 AM   #6
hottscennessey
hottscennessey's Avatar
hottscennessey is an unknown quantity at this point
What turbo, how much boost?
hottscennessey is offline   Reply With Quote
Old 07-13-2009, 11:11 AM   #7
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
sounds like a boost leak to me....
clark is offline   Reply With Quote
Old 07-13-2009, 11:12 AM   #8
DMN
I just unplugged the tps and it runs about the same...
Old 07-13-2009, 11:13 AM   #9
DMN
t28 9psi, but the thing is it seems to hold boost fine
Old 07-13-2009, 11:15 AM   #10
hottscennessey
Sounds like you may be running out of fuel.
I'd do 550's/Z32 MAF and PM me if you want it tuned. It's very reasonable.
Old 07-13-2009, 11:22 AM   #11
DMN
it studders yet smells rich,om thinking coils possibly anyone else think it could be them?, and yes im doing 555/z32 at some point but atm i want to work this out
Old 07-13-2009, 11:27 AM   #12
hottscennessey
I've had people tell me their car smells rich, when we get the wideband hooked up, it's leaning out. You'll be supprised how well a car will run when it's extremely rich.
I definately know what you mean about getting the problem at hand straight, but with a larger then stock turbo you could easily be maxing out the stock fuel system, and could be talking potential damage to your motor.
On the other hand it could be your coils, but I have no experiences with bad coils, so I'll wait for someone else to chime in on that.
Old 07-13-2009, 12:20 PM   #13
DMN
welll i pulled the plugs to take a look and see if that was it and when i put them back in it runs good so i think maybe a coil became loose or something along those lines if anything else comes back ill post here again
Old 07-13-2009, 01:02 PM   #14
rastaman
rastaman is an unknown quantity at this point
low vtec psi
rastaman is offline   Reply With Quote
Old 07-14-2009, 07:47 PM   #15
guitaraholic
guitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of light
The coils HATE to get wet,, just a little water, and you car will run the SHIT!!! Trust me I know
guitaraholic is offline   Reply With Quote
Old 07-14-2009, 08:27 PM   #16
jackal264
jackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud of
i'm having this EXACT issue. i thought i had fouled my plugs so i replaced them but still the problem persists. i'm heading to the dyno tomorrow morning to get a re-tune b/c for me i just slapped on a new intercooler and manifold so i could be leaning out in the mid range.
for me i studder and bog between 2.5 and 4k rpm but above that i run fine.
other things that i recently change are no more bov and a breather filter on the iacv pipe instead of running to the coldpipe.
all of this b/c of an accident. i'm praying the motor comes back to life with a good retune b/c then i'm out of ideas.
jackal264 is offline   Reply With Quote
