Old 07-19-2009, 05:30 PM   #1
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
A/C Idle Issue
K trying to troubleshoot this issue. When I turn my AC on, compressor kicks in, blower works, fan turns on, everything works fine. Only thing is that my Idle isnt bumping up like its supposed to. I got a PFC and did a sensor check, doesnt seem to be seeing the signal that the AC is on. I'm trying to understand how the ECU is supposed to see this signal. Is it a seperate signal thats coming from the back of the AC Controller or is it tied into the system?
This is on a S14 chassis by the way...
CLICK HERE!!!
Old 07-19-2009, 05:40 PM   #2
Sileighty_85
Sileighty_85's Avatar
under the "Idle/Rev" function you can set the idle of what you want when the A/C is turned on.
Did you set that?
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 07-20-2009, 04:18 AM   #3
fliprayzin240sx
Did you set that?
Yup, I already maxed that out, didnt make a difference. Like I said, I checked the sensor check and the AC isnt highlighted.
CLICK HERE!!!
Old 07-20-2009, 02:52 PM   #4
yukon
yukon is an unknown quantity at this point
on the s13, the ecu supplies ground to ficd and a/c relay supplies positive to ficd. the ground from ecu can be interrupted by an ambient switch. i would confirm that the ficd is not getting the ground. the fsm might say how ecu decides to send ground.
yukon is offline   Reply With Quote
Old 07-20-2009, 08:11 PM   #5
jorgezee1
Trader Rating: (22)
jorgezee1 is an unknown quantity at this point
Feedback Score: 22 reviews
if your running an s14sr zenki harness pin number 9 on the ecu needs to see the signal from the triple presure switch.
Check the following
Pin #9 on the ecu
Pin #25 on the white plug
essentailly these correspond to each other. it should be a green/yellow wire.
Note: as stated above check the fsm manual and trace the wire.
jorgezee1 is offline   Reply With Quote
Old 07-21-2009, 02:56 AM   #6
fliprayzin240sx
Imma give it shot, shits a lil tricky for me. Running a hacked up S15 wiring harness/PFC on an S14 zenki chassis.
Right now, Im getting inputs of jumping the ECU all together since all I really need is a signal to the IACV. I was told the IACV gets a 5V input signal to open up for the AC. If its true, anybody know which wire needs the signal? There are 2 plugs going into the IACV.
CLICK HERE!!!
Old 07-21-2009, 04:35 AM   #7
GSXRJJordan
GSXRJJordan's Avatar
Let the ECU figure out what to do with the IACV - opening it all the way when the AC is on might not be the best answer.
Check the pins that Jorge posted first, that could be an easy fix.
Old 07-21-2009, 06:13 AM   #8
fliprayzin240sx
Check the following
Pin #9 on the ecu
Dont happen to know what voltage I should be seeing do you? Fuck I swear, when I tear this car down in less than 2 years, Im gonna go get a brand spanking new wiring harness...
CLICK HERE!!!
