Old 04-23-2003, 09:48 AM   #1
mikeroy420
mikeroy420's Avatar
mikeroy420 is making his/her stupidity well-knownmikeroy420 is making his/her stupidity well-knownmikeroy420 is making his/her stupidity well-knownmikeroy420 is making his/her stupidity well-known
How do you lube the shifter?
How do you lube the shifter? I tried looking it up, but couldn't find anything. What do you use to lube it? Is it difficult to take a part? Thanks.
mikeroy420 is offline   Reply With Quote
Old 04-23-2003, 12:49 PM   #2
nrcooled
nrcooled's Avatar
nrcooled is an unknown quantity at this point
Send a message via Yahoo to nrcooled
I have an s13 so all of my steps will be for that model:
1. Unscrew the shift knob (righty tighty, lefty loosey)
2. Take off the center console cover (it just pops off)
3. Now you will see the rubber boot. It is held in by four 10mm bolts. remove thouse
4. Slide boot up the shifter (it may get stuck on the shift lever just use WD40 to get it off
5. There is a second smaller boot that goes around the base of the shifter. Just peel it back to reveal the shifter seat.
6. Now you can add tranny fluid to the shifter
Use 75w 90 tranny fluid to lube.
Any further questions just PM me. Or post. Or whatever makes you feel good.
FYI Chilton's Manuals will be your best friend
'91 hatch w/ SR Sold; '03 Evo Sold 401 HP; '03 MS Protege sold; '00 Evo 6.5 TME Sold 300HP
nrcooled is offline   Reply With Quote
Old 04-23-2003, 03:19 PM   #3
Keisuke
Keisuke is an unknown quantity at this point
sorry to jack the thread, but this might be the funniest tread i have ever seen!
Jesse
2003 subaru impreza wrx sports wagon
Keisuke is offline   Reply With Quote
Old 04-23-2003, 03:21 PM   #4
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
Chilton's manual makes a better acquaintance. FSM makes a better friend.
AceInHole is offline   Reply With Quote
Old 04-23-2003, 11:23 PM   #5
rancid240
Trader Rating: (72)
rancid240 will become famous soon enoughrancid240 will become famous soon enoughrancid240 will become famous soon enough
Feedback Score: 72 reviews
Re: How do you lube the shifter?
Originally posted by mikeroy420
How do you lube the shltter? I tried looking at it, but couldn't find anything. What do you use to lube it? Is it difficult to take a shlt? Thanks.
rancid240 is offline   Reply With Quote
Old 04-24-2003, 02:33 AM   #6
elevator
elevator is an unknown quantity at this point
How do you lube the shifter?..... What do you use to lube it?
Let your girlfriend ride in the middle!
elevator is offline   Reply With Quote
Old 04-24-2003, 12:56 PM   #7
240 2NR
240 2NR's Avatar
240 2NR is an unknown quantity at this point
If you're talking about adding transmission fluid, the much easier way (versus pulling the shifter) is to open the filler hole on the side of the transmission. If you plan to replace fluid then you can use the drain plug (much like that for the oil) to drain the trans fluid and then close it, open the filler plug and use a small pump (like $6) to fill the trans back up with the "lube" of your choice.
If you remove the shifter there's the chance of tearing the gasket, plus those bolts are a PIA to get at.
VVV FSM tranny pic VVV
Steve
93 240sx FB currently very clean and for sale
240 2NR is offline   Reply With Quote
