Old 07-22-2009, 09:59 PM   #1
frankenfresh
frankenfresh's Avatar
frankenfresh is an unknown quantity at this point
loking for a power fc map
I have a used power fc with an unknown map on it
I am looking for someone who has a tuned map for the same or close to the same mods as me so i can drive my car to the shop to have it fully tuned. anyone who can help out would be awesome.
my mods are:
s13 sr20det, 5spd
hks ssqv (welded onto the cold side)
nismo 550 injectors
z32 maf
blitz filter
s15 t28
megan exhaust manifold
megan turbo elbow
megan down pipe
greddy profec b
greddy front mount intercooler
wlabro 255 fuel pump
BC 264 cams
Brian Crower Valve Spring & Ti Retainer Kit (i think its BC200 or somthing)
rocker arm stoppers
greddy adjustable cam gears
power fc ecu
light weight pulleys
spitfire ignition system and coils
NGK Iridium IX Spark Plug, 7 Heat Range
Wix Z32 Fuel Filter
ISIS Intake Manifold
ISIS underdrive Crank Pulley
sard fuel presure regulator
2.5" hot pipe
3" aluminum rad
nismo thermostat
bigger oil pan
oil cooler
new front timing cover and oil pump
new cam chain tensor
F1 stage 3 clutch
fidanza 9.5lb flywheel
driveshaft shop aluminum 1 piece drive shaft
frankenfresh is offline   Reply With Quote
Old 07-22-2009, 10:31 PM   #2
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
talk to steve shadows... but he'll just do a tune for you... if you pay for it. and it'll be better than the dyno
Slip Gypsies Blog
not sure if you realize this
Old 07-23-2009, 12:17 AM   #3
frankenfresh
how do I contact steve shadows?
you mean he'll be able to give me a full tune without actually having my car?
Old 07-23-2009, 01:35 AM   #4
frankenfresh
i answered my own question, searched his name and pmed him.
also found his website Shadowerks
Old 07-24-2009, 12:37 PM   #5
ANVIL
ANVIL's Avatar
ANVIL can only hope to improve
if u still want it, i can upload u the base map for sr20det, which should be good enough to get it running to drive to your tuner. pm me if you need it
ANVIL is offline   Reply With Quote
