Old 06-07-2010, 10:46 PM   #1
S14_Kouki
S14_Kouki's Avatar
S14_Kouki can only hope to improve
Water boiling in the over flow tank need help please.
I Just got done swapping a s13 sr in my friends s14. We changed the coolant temp switch. The car runs fine. But that weird thing is after driving it the water in the over flow tank is boiling like u can hear it boiling or is it bubbling?? idk Im just wondering if there is still air in the system or is it cause the car is running to hot?? Because I know it should not be boiling/bubbling.
Side question, can u run a ABS drive shaft with a sr swap??
S14_Kouki is offline   Reply With Quote
Old 06-07-2010, 10:51 PM   #2
91JayBlueSupra
91JayBlueSupra is an unknown quantity at this point
Send a message via AIM to 91JayBlueSupra
There could be air in there still. Have the temps of your gauge changed much? You think he HG could be blown is that new? Any loss of coolant?
91JayBlueSupra is offline   Reply With Quote
Old 06-07-2010, 10:56 PM   #3
slider2828
slider2828's Avatar
Compression or leak down test too!! in case small head gasket leak pressurizing the coolant system
Turn and Burn!
Old 06-07-2010, 10:59 PM   #4
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
tired radiator cap not holding pressure thus allowing coolant to boil
happened to me once
Old 06-07-2010, 11:06 PM   #5
I LUV MY S13
I LUV MY S13's Avatar
cooling system not properly bled, thermostat, rad cap..could be any of those
-Jorge
I LUV MY S13 is offline   Reply With Quote
Old 06-08-2010, 08:16 AM   #6
jspaeth
jspaeth's Avatar
happened to me once
I think this is what I have, because I lose maybe 1 or 2 cups of water every month or so, but my compression is great, no white smoke anywhere, no oil/coolant mixing.....
If I fill up the rad and fill up the overflow a bit, in a bout a month, the overflow is empty and there is a little bit of coolant missing from the radiator.....
I was thinking that it was because my 15-year old rad cap was allowing coolant into the overflow, and then it was evaporating from there somehow (crack?, not airtight?)
Daily driven
Old 06-08-2010, 09:42 AM   #7
S14_Kouki
S14_Kouki's Avatar
The guy we bought the engine from said he had a shop replace the bearings, rings, and headgasket before he sold it. The rad cap does look like its seen better days. all ill have to flush the system again. But it does not seem to be losing any coolant.
Old 06-08-2010, 03:20 PM   #8
slideways2004
slideways2004 will become famous soon enoughslideways2004 will become famous soon enoughslideways2004 will become famous soon enoughslideways2004 will become famous soon enough
Send a message via AIM to slideways2004
Bleed the entire system. Get a new a radiator cap. Sounds like an air bubble
slideways2004 is offline   Reply With Quote
Old 06-08-2010, 04:54 PM   #9
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
happened to me once
That^
I would suggest getting the rad cap that has the red handle...when u lift the handle (before opening the rap cap itself) it purges all the pressure to the reservoir, instead of you opening and having a fresh bath of heated cooling...its saved my ass quite a few times...
PSN
& XBL GT : Wh0pp3r68
CLUB LEXUS : Wh0pp3r
Old 06-08-2010, 05:34 PM   #10
S14_Kouki
S14_Kouki's Avatar
Thank you everyone for the help ill try the rad cap and see how that works.
Old 06-08-2010, 11:45 PM   #11
zylvia213
zylvia213's Avatar
Trader Rating: (36)
zylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond repute
Feedback Score: 36 reviews
Send a message via AIM to zylvia213
I know you said you dont have a leak but by any chance do you smell coolant while your driving or stopped at a light? just curious
zylvia213 is offline   Reply With Quote
Old 06-11-2010, 01:02 PM   #12
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
you can usually tell by feeling the coolant lines if a coolant passage in the head gasket was breached... I had that problem after my number 4 cylinder ate a throttle body screw and lifted the HG. The inlet/outlet coolant lines to the block were taught and it would drip at the connections. plus you could look for bubble with the cap off. I bet its what has been mentioned.
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 06-11-2010, 01:41 PM   #13
S14_Kouki
S14_Kouki's Avatar
Well He just tryed driving it to work and it started over heating with the new nismo rad cap. It start bubbling out of the rad so we r thinking its a blowin headgasket.
Old 06-11-2010, 02:26 PM   #14
jspaeth
jspaeth's Avatar
I don't understand what you wrote....why would it overheat with the nismo rad cap..?
Daily driven
Old 06-11-2010, 02:36 PM   #15
S14_Kouki
S14_Kouki's Avatar
He has a ka radiator in the car now and it was over heating with the stock cap. So we chanced the stock cap with the nismo rap cap and it still over heated so we are thinking it has a blowin head gasket.
Old 06-11-2010, 02:39 PM   #16
mattsil80wis
mattsil80wis is making a name for him/her selfmattsil80wis is making a name for him/her self
are the fans coming on?
mattsil80wis is offline   Reply With Quote
Old 06-11-2010, 02:51 PM   #17
I LUV MY S13
if he has a blown head gasket you'd be able to tell by checking the oil and/or coolant, if its milky than the HG is done..another way you can tell is by the color of smoke coming out of the exhaust
-Jorge
Old 06-11-2010, 05:06 PM   #18
S14_Kouki
S14_Kouki's Avatar
Yes the fans are coming on.
Thats the funny thing I dont think its a blowin HG because there is NO smoke from the exhaust and the oil looks perfect NO milkyness to it.
Old 06-11-2010, 05:30 PM   #19
Shadowhunter
Shadowhunter's Avatar
Shadowhunter is an unknown quantity at this point
This happened to me, properly bleeding the system did the trick.
Shadowhunter is offline   Reply With Quote
Old 06-11-2010, 08:52 PM   #20
I LUV MY S13
yeah then its something faulty in the cooling system...follow these steps:
1)take out the thermostat and put in water at 185 degrees (or whatever the temp is for it to open)..if it doesnt open then theres your problem, if it does then proceed
2) take off water pump, if its oxidated, rusty, corroded or any signs of shittyness then just replace it..thats a sign of mineral water being used in the in the cooling system..if it seems fine, then proceed
3) check the fans..wait are they electric or a clutch fan? if its a clutch fan then the silicone on it may be no good, which then results a lack in speed..also check the fins, they're designed specifically to create less air resistance one another..so if one is bent or chipped, then it wont function properly
now if its electric is it dual or single? if its single, replace or buy another..if its dual, well they suck and replace them..but regardless if your fans suck you still shouldnt be overheating while in motion
now when filling it up...grab a 2liter bottle of soda(empty) and fill it up with half coolant and half water, then pour all that into the radiator, proceed till full...to bleed, start your engine with the radiator cap off to avoid building up of pressure and let the engine run for approximately fifteen minutes. Then turn on your heater. This will help circulate the coolant and push out any trapped air. The space that is emptied by the air that has been flushed out could be now used to pour more coolant. Be careful as the air that has been released is quiet hot. Make sure you keep your hands miles away from it as you don't want any injuries. Then you just put the cap back on and wipe of the remaining fluid around it with a cloth or a rag..
now honestly if it were me, i would just buy a nismo themostat, nismo thermo stat, and silicone hoses..
-Jorge
Old 06-11-2010, 08:57 PM   #21
240sxChillen
240sxChillen's Avatar
240sxChillen is an unknown quantity at this point
Its probably a bad water pump! My car would overheat after 2 minutes of driving.
Originally Posted by ayuaddict View Post
if Matej told me a 205/50/15 wont fit on a 15x7, I'd believe him.
240sxChillen is offline   Reply With Quote
Old 06-12-2010, 12:06 AM   #22
S14_Kouki
S14_Kouki's Avatar
The thermo stat does open and the water pump does work, beause we can see the water flowing thur the rad once it is up to operating temps. It has a E-fan (single) and it comes on and blows hard. Im going to pull off the water pump just to look at it. Then im going to properly bleed the system to make sure allllllll the air is out. Ill keep you all updated and THANK YOU for your time and help
Old 06-12-2010, 02:11 PM   #23
s14kdizz
s14kdizz is an unknown quantity at this point
Would having an air bubble in the cooling system cause it to build pressure after 2 secs of runing? Cause if I start it up let it run for a sec then go to remove the rad cap when car is still cold it has enuff press to shoot cold water out of the rad. Headgasket????
Thanks for all the info owner on the car
s14kdizz is offline   Reply With Quote
Old 06-12-2010, 02:13 PM   #24
s14kdizz
Old 06-13-2010, 12:25 AM   #25
xdumbxguyx
xdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to behold
could be a cracked head or bad head gasket
infinitwheels.com
pitgarage.net
xdumbxguyx is offline   Reply With Quote
Old 06-13-2010, 02:04 AM   #26
ddf2006
ddf2006's Avatar
ddf2006 is an unknown quantity at this point
this is going to sound like a dumb question but r u running coolent or straight up water????
i ran water in my s13 wen i first got it and my resevior (wrong spelling) and it boiled. once i switched to coolent, the boiling stopped.
just something to think about.
proobley wrong though... :/
ddf2006 is offline   Reply With Quote
Old 06-13-2010, 02:00 PM   #27
S14_Kouki
S14_Kouki's Avatar
Its all water. We r taking the head off so we will see if its a bad hg or cracked.
Old 06-13-2010, 04:54 PM   #28
Om1kron
Om1kron's Avatar
Most likely, you cant run just water in it. it can cause shit to BREAK inside of the engine.
Wayne Edwards
https://om1kron.blogspot.com
Old 06-13-2010, 05:14 PM   #29
S14_Kouki
S14_Kouki's Avatar
What exactly can break?? From my understanding coolant is to prevent corrosion and prevent water from freezing in the engine.
Old 06-13-2010, 05:35 PM   #30
rdrckt
rdrckt's Avatar
rdrckt is an unknown quantity at this point
change the thermostat,radiator cap and jack up the car on the left front with the car off,open the bleeder screw,wait till all the air bubbles come out while u pour in coolant,now start the car with the car still jacked up and wait till both hoses are the same temp.the thermostat has to cycle at least three times and then you're done.even if the headgasket is bad these things have to be replaced since they most likely are damaged from overheating.also these things are cheaper than replcing the headgasket and possibly the head for no reason.
rdrckt is offline   Reply With Quote
