Old 04-20-2003, 05:36 PM   #1
HKrpS13
HKrpS13 is an unknown quantity at this point
Send a message via AIM to HKrpS13
power window
My passenger side power window seems like it rolls up slower than before. I know it's old and stuff but is it possible so that it rolls up fast like the 2002 model cars?
HKrpS13 is offline   Reply With Quote
Old 04-20-2003, 06:36 PM   #2
Nissan240SX
Nissan240SX is an unknown quantity at this point
Idea
You should check the motor as well as the automatic down on the drivers side. Check the motor on the Passenger side and make sure your getting good power.
If Life is an Andrenaline rush, then why are Hondas so slow?
Nissan240SX is offline   Reply With Quote
Old 04-21-2003, 03:21 AM   #3
HKrpS13
so I should clean the motor and clean all the conections
Old 04-21-2003, 10:00 AM   #4
Dream240
Dream240's Avatar
Normally, they slow down as the motors age. It's unavoidable. You will most likely have to replace the motors, cleaning them might help a little. But if you plan on cleaning it, when you remove it why don't you take it and get it refurbished at a shop that will do the work. Might be worth checking into.
I am having a problem with my driver side rattling when I drive over bumps in my 96 s14. I think the mounting bolts are just loose. So make sure you tighten it back up real tight when you put it back on.
Old 04-21-2003, 11:35 AM   #5
Nissan240SX
cleaning it
He is right cleaning it is only going to speed it up for a short while and that might not work, the only other thing that cleaning it would do it maybe help it seing as there is a lot of build up that occurs in the teeth of the motor which drives the window up. But either buy a set of used ones from someone that knows they are working in tip top shape. I got mine from someone on this forum for like 30 bucks. So they can be had for fairly cheap.
Chris
