Old 08-16-2009, 06:21 PM   #1
Tensor187x
Tensor187x has a little shameless behavior in the past
s14 SR into s13
Hey guys i currently have a 95' 240 with an OBD1 s14 zenki SR in it. I actually want to drop that engine into an s13 vert but not sure if i have to convert the wiring again? Sorry if that doesnt make sens. Will it be a direct drop in? Thanks for the positive feedback.
Tensor187x is offline   Reply With Quote
Old 08-16-2009, 06:38 PM   #2
burnsauto
burnsauto's Avatar
You'll have to convert the engine harness, only a few plugs, but the body harness should work fine with the S14SR.
Old 08-16-2009, 06:44 PM   #3
Black240Ct
Black240Ct will become famous soon enoughBlack240Ct will become famous soon enoughBlack240Ct will become famous soon enough
Send a message via AIM to Black240Ct
yeah you do.
the s14 uses the big white plug next to the ECU as its 'converting' plug.
the s13 uses the white dash plug next to the ECU and the two Grey and brown power plugs next to the battery.
its not a hard job. use a s13 to s13 sr wiring diagram to see what the 'power plug' and 'dash plug' on the vert are
use a fsm or s14 (F4 or F3)plug pinout to see what those wires are. and connect them.
thats how i did mine
Black240Ct is offline   Reply With Quote
