Old 01-11-2006, 03:07 PM   #1
chnco
chnco is an unknown quantity at this point
Alternator Plugs?
Well, I was looking at the FSM to see what plugs are suppose to go on the alternator.
I know there is the normal plug with the harness and then a power wire. Also, is there a ground that goes to the chassis? It specifies that there is, but it seems like I don't have one and couldn't really find a bolt where it could lead to. I do have a black wire from the harness that has a bolt type connector is just hanging there. This is a blacktop in a S13. I'm looking at a DOHC FSM.
My batteries aren't holding a charge.
chnco is offline   Reply With Quote
Old 01-11-2006, 03:25 PM   #2
drifter808
drifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of light
you have to connect that black wire. there is a place on the alternator where it mounts to, it should have a capitalized "E" where it should go. Kind of hard to see though when in the car but it is the bolt hole below the main power wire to the alternator. Maybe that will fix it.
drifter808 is offline   Reply With Quote
Old 01-12-2006, 10:35 AM   #3
chnco
is it a bolt hole or a stud? This black wire has one of those U connectors with a hole that a bolt goes through.
Old 01-12-2006, 07:51 PM   #4
drifter808
Its a bolt hole. The bolt is pretty tiny, it has a 8mm head on it. Is the black wire about an 1/8th inch thick? if so thats the one.
