Old 11-24-2009, 08:15 PM   #1
Almedarj
Almedarj's Avatar
Almedarj is an unknown quantity at this point
Send a message via MSN to Almedarj
s13 KA ticking noise
Ok so heres the problem there is a ticking noise that begins when i get above 3k rpm, now i just had the engine redone but the warranty expired a month ago lucky me. so the shop said they not responsible i dont blame them i know i wouldn't want to be either. but i do know it not the chain tensioner sound i had that issue before and sounds completely different. any one have any ideas and a shop that they recomend
Almedarj is offline   Reply With Quote
Old 11-24-2009, 08:41 PM   #2
Sileighty_85
Sileighty_85's Avatar
check to see if the upper timing chain guide was removed.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 11-24-2009, 08:54 PM   #3
Rasty180SX
Rasty180SX's Avatar
Rasty180SX is an unknown quantity at this point
Send a message via AIM to Rasty180SX
Check your lifters...I had to change mine and the noise went away
Rasty180SX is offline   Reply With Quote
Old 11-24-2009, 09:09 PM   #4
SlideKing92
SlideKing92's Avatar
SlideKing92 is an unknown quantity at this point
I have the same problem if it sounds like its coming from the front of the engine its the timing chain guide, I have a shop will highly recommend depending where you are in CA PM me and i will give you all the info and the price they quoted me to fix that same problem
SlideKing92 is offline   Reply With Quote
Old 11-24-2009, 11:17 PM   #5
fcdrifter20
fcdrifter20's Avatar
Trader Rating: (44)
fcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to behold
Feedback Score: 44 reviews
is it single cam or twin cam???? how many miles since the engine was rebuilt??
fcdrifter20 is offline   Reply With Quote
Old 11-28-2009, 08:41 PM   #6
gots13?
gots13? is an unknown quantity at this point
hey bro i have the same problem with the timing chain I'm in Arcadia how much was it to fix?
gots13? is offline   Reply With Quote
Old 12-01-2009, 06:58 PM   #7
Almedarj
Almedarj's Avatar
the timing chain issue was fixed for 250 at a shop in industry ran by some dude named johnson and ill check my lifters
Old 12-01-2009, 07:16 PM   #8
Shadowhunter
Shadowhunter's Avatar
Shadowhunter is an unknown quantity at this point
Don't pay for someone to do this it is fairly simple and straightforward. New valve cover gasket, remove valve cover bolts in order and carefully.
Make sure your engine is CYL #1 TDC. Remove and mark distro. remove lower cover, Unscrew 2 bolts on two timing chain guides, replace valve cover gasket, and done. Should take 2-3 hours if you have never done it before and are being really careful.
Shadowhunter is offline   Reply With Quote
Old 12-01-2009, 07:41 PM   #9
M11's
M11's's Avatar
M11's is an unknown quantity at this point
having the same problem. all you did was change the lifters on each valve nothing else to fix ticking?
M11's is offline   Reply With Quote
Old 12-01-2009, 07:59 PM   #10
spooled240
spooled240's Avatar
spooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfection
the ticking sound may be valve lash, you'll have to check your valve clearances and compare them to the tolerances specified in the FSM. Basically you get a feeler gauge and see how much clearance you have from the cam and the lifter when the valve is completely closed (and the cam is not touching the lifter at all of course)
spooled240 is offline   Reply With Quote
Old 12-02-2009, 09:24 PM   #11
Almedarj
Almedarj's Avatar
hey guys thanks for ideas and help i'll check on it tomorrow after work
Old 01-05-2011, 09:54 AM   #12
blue rexsti
blue rexsti's Avatar
blue rexsti is an unknown quantity at this point
any updates?
blue rexsti is offline   Reply With Quote
ka24de, s13
