Old 09-12-2009, 06:19 PM   #1
Silviaoneday
Silviaoneday's Avatar
Silviaoneday is an unknown quantity at this point
in your opinion rb25 100amp fuse problem
Hey guys,
Well I have a s14 with an rb25, I recently installed a new timing belt, exhaust manifold gasket, and a t3 flange gasket. I had the alternator polished now I have a PROBLEM, the car will not make it down the street without blowing the 100 amp main fuse. Ive replaced the fuse 3 times today, checked the wires going to the back of the alternator and made sure they werent grounding.... Other then the timing belt being a little tight I'm lost... Any ideas!!
All that I have touched:
1. Cam angle sensor/ but you cant screw plugging it in up
2. Turbo/ self explanitory
3. Alternator,??
THANKS!!
Silviaoneday is offline   Reply With Quote
Old 09-12-2009, 07:29 PM   #2
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
the alternator is over charging and blowing out the fuse.
Review Thread
bardabe is offline   Reply With Quote
Old 09-12-2009, 07:54 PM   #3
Silviaoneday
Yea I had the guy polish the alternator who knows what the hell he did, how do I fix this?
Old 09-13-2009, 09:10 AM   #4
projectRDM
projectRDM's Avatar
Is the plastic insulator on the charging stud cracked or damaged? That would be the first thing to check, if it's fine then he did some kind of damage when polishing it. It's not overcharging though, that would mean the voltage regulator is bad and you'd see increased voltage, not amperage. Something is grounding out, maybe a winding got some grit on it and when it expands from the heat it's touching the case or something similar.
FORMERLY R240NA
Old 09-13-2009, 10:37 AM   #5
Silviaoneday
Well the insulator was cracked but was on there still. I took it off and glued it back together, could that still be a problem? Other then that there is some shit all over the winding as you say from the polish, that could be an issue... The car starts up fine you can turn it on and off, but when you go and drive it and put any form of a power load on it, it will blow the fuse. Im going to get the alternator tested now and see what it puts out. Just to make sure there is the power terminal and one ground wire that plugs in and the pigtail plug on the right side of the alt ( under the vehilce looking forward)??
THANKS GUYS
Old 09-13-2009, 11:12 PM   #6
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Get another alternator, Im willing to bet your alternator is fubar'd and grounding out.
CLICK HERE!!!
Old 09-14-2009, 12:38 PM   #7
Silviaoneday
Well I took the alternator and got it tested, it passed with flying colors...
