Old 04-16-2008, 08:32 PM   #1
timtiminy
timtiminy's Avatar
timtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the rough
Send a message via AIM to timtiminy
lightweight vs. stock flywheel
hey i have heard conflicting oppinions on what flywheel to use on the SR20DET motor. I hear that having a lightweight flywheel gets you into boost faster but it also falls off quicker when shifting and the stock one has the inertia to keep the motor spinning and the turbo spooled, as well as the inertia to help on take off. Are the benefits of a lightweight flywheel worth its downfalls?
timtiminy is offline   Reply With Quote
Old 04-16-2008, 08:39 PM   #2
BoostedCoupe
BoostedCoupe's Avatar
BoostedCoupe can only hope to improve
from what i got from this thread from brian is that it helps rev faster and the revs fall down quicker. if you understand what im saying. I dont see were it would effect boost but with the motor having to spin less weight which allows it to reach peak boost quicker.
http://www.zilvia.net/f/showthread.php?t=187294
92 vert converted 5speed and other little things
BoostedCoupe is offline   Reply With Quote
Old 04-16-2008, 10:16 PM   #3
HalveBlue
HalveBlue's Avatar
HalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond repute
Simple physics.
Less mass is easier to move but will also slow down more quickly.
Personally, I like the ability to have my engine rev up a little bit quicker.
HalveBlue is offline   Reply With Quote
Old 04-16-2008, 11:50 PM   #4
timtiminy
timtiminy's Avatar
so slowing down more quickly would mean that you would drop out of boost correct? I wonder how much of a difference there really is, I havent felt the difference first hand yet, my dad is putting a fidanza on his celica gts this week so i guess i can figure out which way i want to go once i see how it compares first hand. but dang that 2zzge motor already revs like crazy so if it does make a noticable difference it should be pretty nice.
Old 04-17-2008, 12:16 AM   #5
HalveBlue
HalveBlue's Avatar
No. Boost pressure isn't regulated by the flywheel.
If the flywheel is slowing down it's because your transmission is not engaged (geared in neutral) or because you're slowing down in gear. In neither case are you building boost.
Essentially, a heavier flywheel will tend to slow down more slowly. That means that you wont loose as many revs in between shifts. But this is obviously offset by the fact that a lighter flywheel will rotate more quickly therefore reaching higher revs more quickly.
Hope that makes sense, I'm pretty tired.
Old 04-17-2008, 12:22 AM   #6
bo2o
bo2o's Avatar
bo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfection
you loose torque nuff said.
easier to get in spool, but wont have that jump as much or pull kinda of feeling
fS! vlsd ! slim fans ! hid kits ! lug nuts !
http://www.zilvia.net/f/search.php?d...earchuser=bo2o
^^^click^^^
bo2o is offline   Reply With Quote
Old 04-17-2008, 01:04 AM   #7
HalveBlue
HalveBlue's Avatar
Originally Posted by 96Turbo View Post
not correct. a heavier flywheel takes more energy to get moving the same speed as the lighter one (thus taking longer), but once it's spinning the same speed, it will slow down slower than the lightened one. This is because it has a higher rotational inertia. So between shifts you will have a drop in rpm's with the lightened f-wheel compared to stock.
I have no experience with the feeling of driving one, but that's my $.02 from a physics perspective
Uh, I'm pretty sure that's exactly what I wrote. But maybe the sentence structure was too hard to read. Whatever. It's late. And I'm flying to Germany tomorrow.
So, peace out.
Old 04-17-2008, 01:11 AM   #8
96Turbo
96Turbo's Avatar
96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute
wow, not sure what the hell i was doing there.....i completely miss understood your post. think i should get some sleep too. sorry to question your explanation when it was exactly right. shiiiiiit. i need more sleep, less studying & less smoking
96Turbo is offline   Reply With Quote
Old 04-17-2008, 01:21 AM   #9
HalveBlue
HalveBlue's Avatar
NP, dood. Happens to the best of us.
Old 04-17-2008, 01:52 AM   #10
Addicted2Kouki
Addicted2Kouki's Avatar
Addicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfection
Another alternative is to get your stock flywheel lightened by a machine shop.
Essentially, almost the best of both worlds... just its the in between.
Originally Posted by coreansurfer View Post
zenki's are for poors and lames
with the exception of norm who is big ballin
FS:CUSCO,GREDDY,KA-Tparts
Addicted2Kouki is offline   Reply With Quote
Old 04-17-2008, 02:03 AM   #11
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
Launching with a lighter flywheel will be noticeably harder due to the fact that there is less rotating which means less inertia = less rotating momentum. With a heavier flywheel launching will be easier due to the fact that there is "more" rotating mass which means your engine will have more rotational momentum at the flywheel.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 04-17-2008, 02:19 AM   #12
S14DB
AFC #1
S14DB's Avatar
wouldn't have any idiot do that or you'll have chunks of flywheel in our legs.
you don't loose tq. you loose rotational mass. makes it feel laggy when you engage the clutch.
Old 04-17-2008, 02:39 AM   #13
91SuperS13
91SuperS13's Avatar
91SuperS13 is an unknown quantity at this point
You wont really feel a huge difference with just the fly wheel. On average a light weight flly wheel is about 10lbs lighter than stock.
Now match that light weight fly wheel up with a light weight drive shaft and you'll really feel a difference in the quickness of accelleration.
91SuperS13 is offline   Reply With Quote
Old 04-17-2008, 02:42 AM   #14
SoguRacing
SoguRacing's Avatar
Once again..Rotational Mass...
Old 04-17-2008, 02:49 AM   #15
tt99ol
tt99ol's Avatar
tt99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond repute
Send a message via AIM to tt99ol
it feels nice, revs quicker, noticable difference, clutch kicks are easier as it revs alot more with the same kick as stock, you do sacrifice some bottom end but losses are minimal while you open up mid/top power, the car revs smoother past 4-5k and pulls alot harder near redline
once your in boost its better than stock but outside of boost it has less torque but revs quicker
try it unless you plan on drag racing, act prolite is nice, 10.5lbs and chromoly not that crappy aluminum with inserts and is probably cheaper than most with great quality
Need automotive work done in the antelope valley?
Ask me how i can help.
tt99ol is offline   Reply With Quote
Old 04-17-2008, 04:31 AM   #16
sillyvia13
sillyvia13's Avatar
sillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfection
I have a na ka...
alum crank pulley
alum flywheel
Alum driveshaft
and alum wheels
much fun...its as fun as a stock sr20det..
from a na ka...
I need to make a video to show ya...revs like a street bike...I find my self back peddling alot in corners I would normally WOT through....
do it...best bang for ya buck...
I was sad about low end loss, but you dont use it when racing and shit...
PLUS I also drive in 5th gear on 30 mph zones...gas mileage is NICE!!!!
sillyvia13 is offline   Reply With Quote
Old 04-17-2008, 04:37 AM   #17
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
^ curious, how's the noise with the alum. drive shaft? Is it a DSS drive shaft?
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 04-17-2008, 05:02 AM   #18
sillyvia13
sillyvia13's Avatar
WELL SINCE YOU ASKED!!!!!!!! lol
I have soild rear subframe inserts ALUM of course...
and a soild trans bushing...well poly pretty soild...and stock motormounts..and this was a good amount of vibrations..
then once DSS shaft went in...OMG! every little friggin piece of plastic that can make noise does...thats how i found I can drive in 5th doing 35...lol...vibrations go away at 2k rpm...lol...
It is noisy...I have no radio...yet...but all in all. well worth it.
I think I took like 50lbs from drivetrain.
1 lb pulley vs 11lbs
10 lb flywheel vs 25 lbs
dss ds ??? but atleast 15 lbs lighter! and soild no rubber bushing...
and 14 inch ssr alum wheels...mad light!
I love it...more than my sr powered drift car.
KA is my new found love...til I put my rb25 together...
Old 04-17-2008, 05:06 AM   #19
DreamN
DreamN's Avatar
Trader Rating: (54)
lol good to know, thank you. what pulley are you using btw?
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 04-17-2008, 06:29 AM   #20
timtiminy
timtiminy's Avatar
do you think having one will effect rev matching downshifts? making it harder to rev match smoother?
Old 04-17-2008, 07:00 AM   #21
nismo tuned s14
nismo tuned s14's Avatar
nismo tuned s14 is making a name for him/her selfnismo tuned s14 is making a name for him/her selfnismo tuned s14 is making a name for him/her self
my friend HAD a fidanza on his prelude. he had to relearn how to shift because it was harder for him to stay in V-TAK! then less than a year later he was teaching his girl how to drive a 5 speed and she somehow managed to rip 75% of the teeth off the flywheel. but you could tell a difference while it lasted. it chattered a little bit but it wasnt too bad.
nismo tuned s14 is offline   Reply With Quote
Old 04-17-2008, 07:27 AM   #22
sldbyuramg
sldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant future
ok well a lightweight flywheel will help you rev faster which in turn will help you reach peak boost faster...but your not going to just all of a sudden drop to vacuum in between shifts. sure if you just let off the gas and held in the clutch for a few seconds but if your quick shifting your not gonna loose all your boost instantly
sldbyuramg is offline   Reply With Quote
Old 04-17-2008, 07:49 AM   #23
S14DB
AFC #1
S14DB's Avatar
She not know how to start the car? The starting ring is replaceable.
Yeah, Boost is Dump Valve(WG/BOV) dependent. Your exhaust keeps the turbo spinning. If your turbo is spinning down between shifts you need to look at your Waste gate and Boost control set up.
Old 09-01-2009, 11:27 PM   #24
handinpants
FreshColdBeer.com
handinpants's Avatar
Trader Rating: (48)
handinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud of
Feedback Score: 48 reviews
Send a message via AIM to handinpants
i have an act 14lb flywheel and i am making more torque than hp... go figure
handinpants is offline   Reply With Quote
Old 09-02-2009, 01:03 AM   #25
steve shadows
steve shadows's Avatar
YES YES YES
do it.
Lightened Flywheel is the way to go. Go with Chromoly, or if you are on a budget the ACT Street is the one I liked the best for the money.
Pair a lighter flywheel with aggressive Cams (HKS STEP2) and a Larger Throttle body and you will have violent and clean throttle response like you wouldnt believe.
Enjoy
Like Me on FaceBook !
Old 09-02-2009, 01:25 AM   #26
rb25_s13*CHUKI
rb25_s13*CHUKI's Avatar
Originally Posted by steve shadows View Post
YES YES YES
do it.
Enjoy
Throw In some lightweight pullys and a unorthodox main crank pully and you might have too much throttle response!
Obliterate
rb25_s13*CHUKI is offline   Reply With Quote
Old 09-02-2009, 01:28 AM   #27
rb25_s13*CHUKI
I had a findanza 9 lb flywheel and act 6 puck un-sprung with extreme pressure plate and I felt almost no drop with shifts and the motor still gave me that pull feeling. **I miss that motor!** get a lightweight flywheel! You wont regret It!
Obliterate
Old 09-02-2009, 01:41 AM   #28
landins13
landins13's Avatar
landins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choices
you wanna go superlight get a lightweight driveshaft and a knife edged and lightened crank too. driveshaftshop aluminum driveshaft 9lb flywheel and an xs engineering 14lb crankshaft my motor responds better than my r6
NO HANDS IN PANTS!!
landins13 is offline   Reply With Quote
Old 09-02-2009, 07:39 AM   #29
chibo
chibo's Avatar
chibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfection
Send a message via AIM to chibo
Your r6 is broken then.
I have a fidanza flywheel on my car, I hate it. Makes it too touchy driving around in traffic.
I loved the E36 M3 I had with a M5 Clutch and lightweight flywheel, that was pretty much a goddamn awesome car.
1989 S13 | 1996 S14 | 2001 E46 | 2009 ZX6R
chibo is offline   Reply With Quote
Old 09-02-2009, 06:52 PM   #30
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
I'd go for ~15lbs for a flywheel on a daily driven car
that's what I plan to do on my car
drove a car with a 11lbs one for a while and though it was fun
stop and go traffic was a annoying
