Old 11-17-2009, 05:06 PM   #1
Blackzenki82
Blackzenki82 is an unknown quantity at this point
Send a message via AIM to Blackzenki82
SR20DET issues
so yeah, trying to finish this car off, and I'm having a few issues...
idles OK, a sputter here and there....
under acceleration, it's smooth till about 1500RPM then starts breaking up, popping, and just losing power, i've already put two different MAF's on the car, did a boost/vac leak test, so system is sealed...
i checked time, with a light, and was close enough for gov'mnt work, if not spot on...
i also checked TPS signal, was at .57V and put it at the .45 as used by Nissan...
engine grounds were loose, so i tightened, and even added one on the driver side... and that helped with the idle, as well as setting the TPS...
tomorrow I'm going to pull the valve cover off, and check cam timing, and restab the CAS....
to me, it feels like a boost/vac leak, but like i said, i put an aircompressor on the turbo inlet, and found all leaks (at the couplers), and even went ang got a GReddy hot pipe and HKS SSQV with super low miles for it (as the TurboXS RFL that was on it was leaking like a bitch, and still, no joy..
SO, with that being said, there's a few more things i'm going to check-
Cam/CAS timing
MAF signal (as it MAY be the problem)
spark plug gaps
compression test (although 0mile motor built by a professional)
one more thing, with a blown T25 cause it to run like that? i noticed the T25 on it has a fair amount of shaft play, but not as bad as i've seen on some cars, and does spin freely....
usually i handle my own shit, but here i'm getting kinda stumped, especially if my cam timing ISN'T off....
Blackzenki82 is offline   Reply With Quote
Old 11-17-2009, 05:13 PM   #2
BlitzRPS13
BlitzRPS13's Avatar
BlitzRPS13 has a little shameless behavior in the past
What kinda fuel pump you got in there?
BlitzRPS13 is offline   Reply With Quote
Old 11-17-2009, 05:23 PM   #3
Blackzenki82
WB 255, with a Z fuel filter
