Old 11-28-2009, 08:34 PM   #1
DrIvEsldEwAyS
DrIvEsldEwAyS is an unknown quantity at this point
squeeling noise.
just put a new clutch and trans in my 240. (pulled motor to do so)
i just got it wrapped up tonight and started it up. i have a few problems.
1. It turns over slowly. doesnt get worse or any better just turns slow then fires up. ideas?
2. With the clutch pedal pushed in and with it let out, the car makes a LOUD squeeling noise. (just as loud if not louder than open DP.) i reused the throwout bearing that was already on the trans, (has less than 5k miles on it, didnt even remove it) and we tightened the pressure plate. never removed the flywheel. now the car did sit for a few months, also the motor sat for a month without the trans on it so there might be surface rust on flywheel. but other than that, what could be causing this sound. i am not 100% sure where it is coming from due to open DP but it sounds like the area of the starter.
thanks!
-1990 240sx hatch sr20det- gt35r, blah blah blah
DrIvEsldEwAyS is offline   Reply With Quote
Old 11-28-2009, 08:47 PM   #2
shocker
shocker is an unknown quantity at this point
you shoulda re surfaced the fly wheel and i never reuse throwout bearings. even sometimes new throwout bearings can be bad out of the box (like my last once i got in my exedy box)
shocker is offline   Reply With Quote
Old 11-28-2009, 08:52 PM   #3
DrIvEsldEwAyS
yeah i know i wasnt thinking, the trans came out my buddies car so i know there was no previous problems. and the flywheel has like ~3k miles on it.
Old 11-29-2009, 07:58 AM   #4
DrIvEsldEwAyS
nothing???
Old 11-29-2009, 08:07 AM   #5
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
your throwout bearing or also called clutch release bearing is going out. replace it.
the squealing happens when you step on the clutch.
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 11-29-2009, 08:32 AM   #6
DrIvEsldEwAyS
so it would squeel so loud i can hear it over open DP? also it squeels when the clutch isnt pushed in?
Old 11-29-2009, 08:42 AM   #7
ChristopherL
ChristopherL is an unknown quantity at this point
Could be the pilot bearing as well. I had that problem, clutch in or out it squeeled. And yes, it would be very loud. Very very loud.
ChristopherL is offline   Reply With Quote
Old 11-29-2009, 09:53 AM   #8
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
just to be sure i would eplace both the throw out bearing and your pilot bearing, and make sure you grease them up.
redline racer510 is offline   Reply With Quote
Old 11-29-2009, 05:56 PM   #9
chrisa
chrisa is close to perfectionchrisa is close to perfectionchrisa is close to perfectionchrisa is close to perfectionchrisa is close to perfectionchrisa is close to perfectionchrisa is close to perfectionchrisa is close to perfectionchrisa is close to perfectionchrisa is close to perfectionchrisa is close to perfection
Send a message via AIM to chrisa
If your gonna take your trans back out replace BOTH the pilot and the throwout.
And the turning over slowly sounds like a weak battery.
chrisa is offline   Reply With Quote
Old 11-29-2009, 06:28 PM   #10
DrIvEsldEwAyS
it was my starter. it was retracting completely. problem solved, hit boost for the first time in 5 months. WOOOOOO
Old 11-29-2009, 06:47 PM   #11
Ceepo
Ceepo's Avatar
Lol all that stress over your starter ha ha ha...
