Old 10-01-2008, 08:27 PM   #1
jonnybonds84
jonnybonds84's Avatar
jonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to all
Rebuilt KA or not, you be the judge!!!!!!
So I bought this motor and its suppose to have been rebuilt 3500 miles ago. The clutch is new, pretty clean looking. It's suppose to have a full valve job done on it, new gaskets/ head gaskets, new piston rings, main and rod bearings new tming chain and guides. I got it from a good source but I wanted to take of the emmision stuff off the intake mani and that gasket looks like its the original one. I just wanna get the zilvia pimps opinions...................so tell me YAY or NAY before I break it down more...PICS in just a few minutes.
jonnybonds84 is offline   Reply With Quote
Old 10-01-2008, 08:37 PM   #2
Fries
Fries's Avatar
yeah can't help with out pics. Look into the valve cover. How clean does it look in thurr?
Old 10-01-2008, 08:45 PM   #3
S14DB
AFC #1
S14DB's Avatar
Probably just pulled the manifold off the head leaving all the accessory's on it. Check the HG and Main/head studs. If the motor is in the car just pop the VC off.
Old 10-01-2008, 09:18 PM   #4
jonnybonds84
OK-K-KAY here are the pics, soooooo should I keep breaking her down or what?
Old 10-01-2008, 09:22 PM   #5
jonnybonds84
Clutch is new, water pump was told is new, it has the exhaust gaskets looking new. I don't really know how to tell if the timing stuff got replaced. The headgasket I guess could be new, maybe?? Let me know what you guys think, pics upon request.
Old 10-02-2008, 07:52 AM   #6
tastyratz
tastyratz's Avatar
tastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to behold
Send a message via AIM to tastyratz
water channels look frickin gross.
that head looks like its been hot tanked - when you look by the cams all the oil is gold and there's no nasty brownish burned on residue like you would see on an engine that hasn't been.
Looks still dirty though and it doesn't look like they really took the time to go the extra mile.
In comparison here are pics of my sohc when I just did my rebuild:
tastyratz/engine - Page 1 - Photobucket - Video and Image Hosting
I also went completely overboard with that too as you can see.
Looks like a half assed rebuild if you ask me. Been sitting awhile? That waterpump and channel on the front cover look more like rusty sawdust than clean and fresh.
Those exhaust ports are friggin GROSS. Looking at the buildup there they didn't do valve seals/ (or guides if need be) but you should before you put it in.
Get some cheap brass freeze plugs while its on the stand and out of the car.
tastyratz is offline   Reply With Quote
Old 10-02-2008, 08:34 AM   #7
S14DB
AFC #1
S14DB's Avatar
Looks like the only thing done to it is a 120k Timing Job. Why they put the top guide back on I dunno. Water Pump is not OE and it looks to have sat with plain water in it for a year or more. I've had motors sit filled with 50/50 anti-freeze look like brand new aluminum in the front cover after 2 years.
The Head Gasket and Bolts are stock and I doubt the Head has been removed. Head has not been hot tanked. Would look brand new if it did, not that golden oil vanish color. Probably just sprayed with a pressure washer to get the sludge out.
No "Valve Job" has been performed. Can see oil leaking from the stem seals. Who Reuses the stock valves? All those deposits are not from 3500 miles.
That oil pan sealing looks like shit so you may as well take it off and redo it and take pics of the crank, mains and oil pump.
Old 10-02-2008, 08:51 AM   #8
98s14inaz
98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection
You got hosed. That motor wasn't even hot tanked which is something they should have done when they had the motor and head apart. Absolutely filthy, no way it was rebuilt 3500 miles ago.
-Retired
98s14inaz is offline   Reply With Quote
Old 10-02-2008, 09:02 AM   #9
tastyratz
tastyratz's Avatar
wait taking a second look at that thing... you don't have any oil in it do you? I thought the gold was fresh oil but if you don't have any there its varnish... If the gold IS fresh oil then they could have just carb cleaner-ed out the brown varnish.
Old 10-02-2008, 09:06 AM   #10
Om1kron
Om1kron's Avatar
hahaha omg wow... yeah dude break it down and rebuild it. The head is full of carbon and you can clearly see white residue all over the valve stem. Either running too lean or rich in that cylinder or it's from detonation.
Wayne Edwards
https://om1kron.blogspot.com
Old 10-02-2008, 09:31 AM   #11
projectRDM
projectRDM's Avatar
Agreed with all. Someone used a few cans of carb cleaner on the head and timing components and called it rebuilt. Nothing on that engine is new.
FORMERLY R240NA
Old 10-02-2008, 02:04 PM   #12
jonnybonds84
The engine does have oil in the head but its not hot tanked cleaned. It's kinda hard to tell if the timing was redone, Im going to take off the head I guess and break it down completely. How much would a head rebuild cost if I do it myself???? I already bought a fel-pro head gasket kit and oil pan seal that Im going to slap in there. is there any way to tell if the engine bearings are newer?? Im taking off the oil pan today since that liquid gasket looks like crap. Oil pump suppose to be new too but HA! we'll see.
Old 10-02-2008, 02:14 PM   #13
xsparc
xsparc's Avatar
xsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to behold
Send a message via AIM to xsparc Send a message via Yahoo to xsparc
Like everyone else said, looks like the just did the timing chain stuff, but the gears look kinda worn. I dont think they even touched anything on the head.
No... no one stole my interior... its safely in my garage...
xsparc is offline   Reply With Quote
Old 10-02-2008, 06:18 PM   #14
jonnybonds84
Quick question will anything happen to the engine if I put it upside down while its on the stand???? Anyone got good trick or tip to take of the cam sprockets? Its giving me problems.
Old 10-02-2008, 09:38 PM   #15
xsparc
xsparc's Avatar
Nothing will happen to it as long as the parts are still attached and you drained all the fluid. for the cam sprockets you have to hold the cam shaft with a wrench and turn the cam bolt with another, might need a breaker bar depending on how long they have been on there.
Old 10-03-2008, 12:11 AM   #16
MAGILLA
MAGILLA's Avatar
MAGILLA will become famous soon enoughMAGILLA will become famous soon enoughMAGILLA will become famous soon enoughMAGILLA will become famous soon enoughMAGILLA will become famous soon enough
you can flip it if nothing is loose. once you remove the cams, also remove the lifters over the springs, with a magnet, before flipping. I labeled mine just in case.
As for the cam sprockets impact gun, or large wrench and a breaker bar. I would suggest the impact or find some one with one, 10 secs max
Also to answer what you asked earlier about the head. I would say just let a good shop do it. I have about $200 in mine but that included 3 angle, seals, hot tank, complete tear down/ rebuild, tolerance check, decking, and so on( the works). I am sure you can get out for a lot less. its too cheap to home job it and jack it up.
~good luck
MAGILLA is offline   Reply With Quote
Old 10-03-2008, 12:31 AM   #17
jonnybonds84
That price doesnt sound bad for a full head work, Im already ordering the calico engine and rod bearing set, I know you can't reuse the headstuds so Im also ordering those since i wanna change out the headgasket since I bought the felpro kit. Im on a budget so.....
ARP head and main studs: $220
head work: $200 hopefully
Felpro kit: $120
Calico bearings: $110
Piston rings: $110
Keeping the timing stuff: $0
Keeping Water pump (no shaft play): $0
Altima fans: $70
Mishimoto Rad: $230
I haven't broke down the block yet, he said did some work on the block ( honed or something) so I don't think Im going to put any money into it unless it looks bad......Oil pump? we'll see, maybe you guys could help me out with that one cause I don't know what im looking forfor that one. More pics once I get the damn sprockets out, lol. Let me know if you guys recommend anything that won't break my bank.
Old 10-03-2008, 03:46 AM   #18
S14DB
AFC #1
S14DB's Avatar
Don't flip the head unless you want to re-bleed the HLA's
Get a new OEM oil pump/front cover. Get a new OEM water pump too.
What's the compression on it? Why are you replacing the rings?
Old 10-05-2008, 05:12 PM   #19
jonnybonds84
Hey I thought that DOHC KA's didn't have any HLA's. I thought SRs had em, I looked at the FSM and found nothing just to make sure. If there is can someone point it out. Im currently waiting on a compressor to take off the cam sprocket cause Im not gonna be able to take it off by hand.
Old 10-05-2008, 10:18 PM   #20
jonnybonds84
I wasn't trying to give out names but I guess someone was going to catch on soon. Sucks that even people with good reps sell stuff like this. How do you know he sold it to me?
Old 10-05-2008, 10:40 PM   #21
Rnz520
Rnz520's Avatar
Rnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud of
Send a message via AIM to Rnz520
dude that motor is kinda hurting, when the valve seals are leaking that bad you should know its not from 3500 miles of use. My motor that came out of my car before I did a through OEM rebuild had 165k on it and didnt look that rough, even the head looked cleaner than that, but I did change my oil very frequently.
*93 240sx:KA-T, FLTA-2s, MR TR, Greddy F&R bars, Greddy gauges, Cusco brace, etc
Rnz520 is offline   Reply With Quote
Old 10-05-2008, 10:58 PM   #22
ChicagoS14
ChicagoS14's Avatar
ChicagoS14 is making a name for him/her selfChicagoS14 is making a name for him/her self
Send a message via AIM to ChicagoS14
WOW that looks horrible..... my motor with 113K and a turbo is cleaner then that.... Ive been running royal purple for the past 14K and after taking off my valve cover to do my gasket the head looked brand new.... shit even my spare block that had over 200K from my buddies car looked better then that....
95 240SX 1JZGTE | SC300 2JZGE daily
www.240sxguide.com
ChicagoS14 is offline   Reply With Quote
Old 10-05-2008, 11:50 PM   #23
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
Originally Posted by soreballz View Post
Damn dude, Spencer fucked you pretty good on that one.
Good luck with all this.
wow...which spencer?!?!?
PSN
& XBL GT : Wh0pp3r68
CLUB LEXUS : Wh0pp3r
Old 10-06-2008, 12:22 AM   #24
importdude
importdude's Avatar
importdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond repute
Send a message via AIM to importdude
Felpro kit: $120
Piston rings: $110
Altima fans: $70
Mishimoto Rad: $230
110 for piston rings is a bit steep
last time i had to order a set it was ~50 bucks
also calicoated bearings? do you really need this? are you going boost?
if not simple acl will work fine ~50 bucks
also if not going boost there is no point in arp hardware.
importdude is offline   Reply With Quote
Old 10-06-2008, 12:35 AM   #25
1989rps13
1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute
Send a message via AIM to 1989rps13
that water pump looks like shit
1989rps13 is offline   Reply With Quote
Old 10-06-2008, 01:02 AM   #26
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
EDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfection
Feedback Score: 53 reviews
so put a negative review on spencer. and wtf? Spencer is a jackass whoever he is. i will not forget his name.
Old 10-06-2008, 02:00 AM   #27
apex
apex's Avatar
Trader Rating: (44)
apex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfection
Feedback Score: 44 reviews
i think it was this guy sorry wrong guy
http://zilvia.net/f/sale-items/21451...650-socal.html
Red Rocket
apex is offline   Reply With Quote
Old 10-06-2008, 11:38 PM   #28
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Originally Posted by apex View Post
i think it was this guy was he the one selling the sr full of dirt too??
http://zilvia.net/f/sale-items/20945...socal-lbc.html
ohh ok
i thought it was smeone else in question....*relief*
PSN
Old 10-08-2008, 07:00 PM   #29
jonnybonds84
No it wasn't that Spencer, I e-mailed him the thread waiting to see if he responds. Today was a good day I guess, I got my clevite engine and rod bearing set, arp head and main stud hardware ( planning to boost later on), free air compressor and lent impact gun. I got stuck in the cam sprockets when I was tearing it down. SO I can advance now. I wanna take a look at the oil pump and cylinders.
Old 10-10-2008, 10:35 PM   #30
jonnybonds84
Soooooooooooooooo, I guess I suck at life, I still can't take off the damn sprocket bolts even with a impact gun. Anyone got good advice? Help me!
