Old 12-09-2009, 06:52 PM   #1
nrmskate
nrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura about
SOHC to DOHC Questions (Swap is complete)
Okay, so I finished up my sohc to dohc swap the other day and it fired up first try, but I shut it off after a few seconds seeing that I don't have the ps/waterpump belt on.
The reason I don't have it on yet is:
A) I only have the SOHC pully, it fits on the DOHC but has 3 ribs instead of 2, and I don't know if the SOHC and DOHC waterpump pullys are the same diameter, if they were the same diameter, would the ribs really even matter?
B) I don't have the entire PS setup connected because im missing a line and don't want to run a dry PS pump, because frankly, I don't want to wear the bearing in it dry
So, my questions are, can I use the SOHC waterpump pulley on KA24DE?
and will the PS line that runs along the engine crossmember work for DOHC setup, or do I have to use the DOHC line, the rest of the lines are DOHC, the only line remaining from the SOHC is the one running along the x-member. I would go look and compare the too, but, it's -3 degrees outside.
Thanks.
nrmskate is offline   Reply With Quote
Old 12-10-2009, 03:28 PM   #2
nrmskate
Aynone?
Are the S14 and S13 PS lines that run along the crossmember the same?
Old 12-10-2009, 05:42 PM   #3
Jonnie Fraz
Jonnie Fraz's Avatar
Trader Rating: (29)
Jonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfection
Feedback Score: 29 reviews
Send a message via AIM to Jonnie Fraz
Originally Posted by nrmskate View Post
Aynone?
No they are different.
Stealth-Custom-Fab.com
Jonnie Fraz is offline   Reply With Quote
Old 12-10-2009, 06:25 PM   #4
nrmskate
So I cant use that main S14 hardline on the rest of my S13 DOHC setup?
