Old 10-13-2009, 06:45 PM   #1
91 240
91 240 is on a distinguished road
Fully built SR
I am parting out my current setup and going with something completely different. This is my fully built SR20DET with only 1100 easy break in miles. Motor has never seen boost and has solid 160psi compression and 2% leak down across all 4 cylinders. Motor is built for 600 whp! Here is the build list and everything included, i also have receipts for all parts and labor:
Aftermarket parts
S13 redtop motor
Apexi cylinder sleeves
Crower rods (not Brian Crower)
CP 87mm pistons 8.5 compression
ARP main studs
ARP head studs
Greddy oil pan
Cometic MLS head gasket
Comp Cams valve springs
HKS 272 step 2 cams
Greddy rocker arm stoppers
MMR polyurethane motor mounts
ACT 6 puck clutch kit
New OEM parts
Main bearings
Rod bearings
Thrust bearings
Front cover/oil pump and front main seal
Water pump
Timing chain and crank gear
Updated timing chain guides
Timing chain tensioner
Rear main seal
Valve stem seals
Water temp sensor
Machine Work
Balance/polish crank
Balance rotating assembly
Sleeve install/bore/hone
Align hone mains
Decked block and head
5 angle valve job
Other accessories and items included
CAS
Alternator
Starter
Coil packs
Power steering pump with DOHC s13 reservoir
Autometer oil temp sender in oil pan
Coolant temp cluster gauge sender removed and tapped for Autometer 1/8 npt sender
Stock oil pressure sender removed and has Autometer 1/8 bspt ->1/8npt fitting
Heater hose hard lines have nipples removed and welded shut
Stock PCV removed and -10AN fitting has been welded to valve cover for crankcase evac
Open to reasonable offers only.
Please PM or email at [email protected] if interested or for any questions. Thanks.
91 240sx
03 Pathfinder
91 240 is offline
Old 11-12-2009, 10:53 AM   #2
s13.5dream
s13.5dream is an unknown quantity at this point
how much are you looking to get for the engine
s13.5dream is offline
Old 11-15-2009, 12:38 AM   #3
mpjustchilln
mpjustchilln is an unknown quantity at this point
pm me your best price
mpjustchilln is offline
Old 11-23-2009, 09:33 PM   #4
91 240
last chance, any offers?
91 240sx
03 Pathfinder
91 240 is offline
Old 11-24-2009, 07:14 PM   #5
babillaracing
babillaracing is an unknown quantity at this point
nice build ,prety well build
babillaracing is offline
Old 11-28-2009, 10:23 AM   #6
91 240
forgot to mention, i have receipts for all parts and machine work
91 240sx
03 Pathfinder
91 240 is offline
Old 11-28-2009, 12:49 PM   #7
NMs14.5kouki
NMs14.5kouki's Avatar
Trader Rating: (38)
NMs14.5kouki is an unknown quantity at this point
Feedback Score: 38 reviews
do you want to separate? im interested in just the block?
NMs14.5kouki is offline
Old 11-28-2009, 01:19 PM   #8
mattro
mattro's Avatar
mattro is an unknown quantity at this point
i wish i had the money for this, my engine is toast.
grip like roots, float like leaves.
wtb s13 sus.
mattro is offline
Old 11-28-2009, 02:17 PM   #9
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
will you part i just want the head with all the goodies. if you do pm me
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline
Old 01-25-2010, 07:10 AM   #10
ichihachizero
ichihachizero is an unknown quantity at this point
I want to buy it how much?
ichihachizero is offline
Old 01-27-2010, 08:45 PM   #11
91 240
Sale pending
91 240sx
03 Pathfinder
91 240 is offline
Old 01-28-2010, 06:30 PM   #12
reccakun08
reccakun08's Avatar
reccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the rough
who built the motor?
reccakun08 is offline
Old 02-02-2010, 11:04 AM   #13
91 240
SOLD! Please close thread
91 240sx
03 Pathfinder
91 240 is offline
