***90 2+2 Pearl White Twin Turbo 300zx CHEAP!!!***
Selling my 1990 pearl white 300zx 2+2 twin turbo that was recently involved in a fender bender. This is fixable and it needs a driver fender, front bumper,radiator support needs a little straightening driver turbo (think bearing is going) and possibly a lower control arm. The car has 102k on the chassis and the motor has 7k to be exact. The car has alot of extras which will be listed below. The motor still has manufacture warranty until october 2010 which covers the block internally or externally. Currently boost is at 14psi. Any Questions feel free to ask. Im not here to scam no one. Asking $5800 OR BEST OFFER!!
I HAVE RECIEPTS FOR EVERYTHING SO NOTHING IS MADE UP. THESE PARTS ALONE ARE $5500+ ALONE. DO RESEARCH!! IF SERIOUS I PREFER CONTACT THROUGH EMAIL. LEAVE YOUR NAME AND NUMBER [email protected] MODS -JWT aluminum flywheel -Noltec urethane motor mounts (blue) -JWT Street clutch -Rear Main seal installed -Nismo radiator cap -60k Timing belt kit installed -OEM oil pump installed -New oil pump gasket -TT hardpipes -Z1 short shifter -Z1 lower radiator hardpipe -Front mount intercooler (Doesnt eliminate support bar like others) -Every lightened pully installed -Koyo racing radiator -OEM remanufactured alternator -Reworked injectors from Z1 (cleaned/balanced/calibrated) -Fluidyne electric fan with sensor attached to coolant pipe-(currently off the car but included) -Ashspec ecu upgrade (14psi) -New Inlet tube,driver side turbo air inlet hose, passenger side inlet tube turbo air inlet hose ordered from courtestparts.com -New engine harness -Greddy intake -Plenum intake gasket -left side valve cover gasket -Right side valve cover gasket -PCV valves -Drilled slotted front and rear rotors with new brake pads -New clutch master cylinder -Test pipes -Full exhaust (unknown-came with 2+2 when it was NA) -Megan racing downpipes -boost guage -RFL BOV's (LOUD) -Boost controller -19'' MRR GT1 Wheels with brand new tires (9.5 all around) (wheels retail $1,200 new) -Stillen wing (real..no fake ebay knockoff) -Stillen rear bumper (Will include extra set of foglights, fog light ducts, and support bar if needed with car) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
