Old 02-11-2010, 07:00 PM   #1
Gymbob
Gymbob is an unknown quantity at this point
Wheel whores where are you?
Basically lol... i thought this fender was 40mm but now i test fitted it, it seems to fit ok anyhow on 18x12.5j et0 275/35/18
Bearing in mind on the pic the standard arch is sat on the tyre so when its cut obviasly it'll be flush
Anyway now the back is pretty much sorted that just leaves the front... now i have 20mm front fenders... and im running a 18x9.5 et0 (but need a 10mm spacer to clear the caliper) so 18x9.5 et - 10 tyre size is 225/35/18 but heard a 40 would be better for front (i gather this is for the extra weight)
Anyway this is where im at, at the minute the front tyre is sticking out by 20mm from the arch!!
in these pics i had around a 8mm spacer on but it does clip the caliper so needs to be around 10mm also the tyre size is a 245 in the pics 225 now... but still it sticks out 15/20mm
Right now i think i have like 1 degree of camber or something on the front wheels im unsure but you can see it very slight sometimes.. probs not even that... anyway my question is how much camber will i need?
I don't want to run stupid camber as i don't have uprated knuckles yet and want the grip for drifting so would it be a better option for me to just buy 30mm front fenders??
Gymbob is offline   Reply With Quote
Old 02-11-2010, 07:25 PM   #2
revat619
Retired General
revat619's Avatar
revat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfection
-1 degree of camber for your front wheels is terrible for grip in general. When the wheels turn they angle over so you want more negative camber so that when that happens you have the most contact patch. Try at least -2.5 to -3. That's really not that much. You want low camber in the REAR for grip. -1 for the rear is perfect.
www.Jspec.com
www.SpeedAlliance.com
www.PoweredByMax.net
Instagram: @rjsladerade
revat619 is offline   Reply With Quote
Old 02-11-2010, 07:42 PM   #3
Gymbob
im not 100% sure it has 1 degree camber maybe its just stock so having -3 on the front won't mess up the handling etc? itll make the front grip more?
Old 02-11-2010, 07:43 PM   #4
NINJASPY
NINJASPY is on a distinguished road
You want 225/40/18 because it is a 25inch diameter tire. 225/35/18 is about 24inches, too small.
24.5-25.5inch fits about right. Stretching the tire also reduces the diameter slightly.
with a 225/40/18 and some camber it will fit fine with the 20mm overs.
A 225/275 stagger seems like a lot of rear grip, but also depends on tire compound/power/driving style.
plus you are offroad... lower it more.
NINJASPY is offline   Reply With Quote
Old 02-11-2010, 07:49 PM   #5
Gymbob
ok i get you but wouldnt a 225/40 therefore create more diameter.. aka more to hit aka needing more camber?
And if you finished reading it all in my original thread u'll see its sat on the metal of the standard arch as its not been cut yet..
Old 02-11-2010, 08:31 PM   #6
99maxgtr
99maxgtr's Avatar
Trader Rating: (22)
99maxgtr has made poor choices99maxgtr has made poor choices99maxgtr has made poor choices99maxgtr has made poor choices99maxgtr has made poor choices99maxgtr has made poor choices99maxgtr has made poor choices
Feedback Score: 22 reviews
Tha'ts b/c he's running 3" larger rear than the fronts lol.
9.5-10 on 20mm is eazzzy peaazzy. and -1 degrees is nothing for the front. i'd do atleast -2~3 degrees and your golden. btw show us some pics of your wheels!
You're 16. You barely know what kind of girls you like.
99maxgtr is offline   Reply With Quote
Old 02-11-2010, 09:19 PM   #7
Gymbob
ye but i need 15/20mm lol is that still easy peasy? lol and the works could do with a ferb but there ok atm
il get some better pics when its all done so 3 degrees is what i need?
Old 02-11-2010, 11:33 PM   #8
dawagarage
dawagarage's Avatar
dawagarage is an unknown quantity at this point
i apologize for the interruption but gymbob who makes that rear bumper?
dawagarage is offline   Reply With Quote
Old 02-11-2010, 11:36 PM   #9
70newport
70newport is an unknown quantity at this point
im no pro at this but -2 or -3 should be about perfect keep in mind the top of the wheel/tire is going to come in when your suspension moves giving you a little more clearance as well so you dont have to get them in that much. i run a 225/35 r 18 on 18x9.5 +15 with a 10mm spacer on factory fenders and it fits about the same as yours. with 2 degrees it would be flush. Just my thoughts.
70newport is offline   Reply With Quote
Old 02-12-2010, 07:40 AM   #10
Gymbob
Its a Uras type 4 kit
But its not clearance from the suspension i need its clearance from the brake caliper which is why i need the 10mm, so for every degree on a 18 inch wheel how much arch clearance does that give you? around 5-7mm?
Old 02-12-2010, 07:09 PM   #11
revat619
Retired General
revat619's Avatar
It won't mess up the handling and yes, it will grip way better.
If your front wheels are like this: l l
under load they will look like this: \ /
That is NOT what you want.
If your front wheels are like this: / \
under load they will look like this: l l
you'll have full contact patch. That is what you want.
www.Jspec.com
Old 02-12-2010, 07:30 PM   #12
azndoc
azndoc's Avatar
Trader Rating: (47)
Feedback Score: 47 reviews
-3.5 is standard.
Old 02-12-2010, 07:58 PM   #13
yokotavia
yokotavia's Avatar
yokotavia will become famous soon enoughyokotavia will become famous soon enoughyokotavia will become famous soon enoughyokotavia will become famous soon enough
Send a message via MSN to yokotavia
get a the right sized tire and throw a 10mm spacer on there and lower that car to make it proper
shit is pretty good fitment
Banana boat chronicles
yokotavia is offline   Reply With Quote
Old 02-12-2010, 10:19 PM   #14
Gymbob
Right so any idea il need how many degrees to tuck 15/20mm?
Also should i get a 225/40 tyre not 35?
Old 02-13-2010, 08:31 PM   #15
Gymbob
or is it just trial and error when you get there lol
Old 02-13-2010, 08:47 PM   #16
FusionR240sx
FusionR240sx's Avatar
FusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond repute
Send a message via AIM to FusionR240sx
i had 18x9.5-4 w/225/40 and prolly -3 camber.
i just maxed the top plates out almost
on stock fenders.
i dont see why with 10mm spacers you can't clear your fenders.
Originally Posted by Wreckless35 View Post
still be flush dropped on KYB AGX struts & s-tech springs
WUT?
FusionR240sx is offline   Reply With Quote
Old 02-13-2010, 08:54 PM   #17
FusionR240sx
honestly.. it was pretty much tucked..
do you have different hubs or something?
WUT?
Old 02-14-2010, 08:46 AM   #18
Gymbob
No i dont :S
Think its time for a re test fit and let the suspension settle etc..
Old 02-14-2010, 11:37 AM   #19
FusionR240sx
No i dont :S
yea put the car on the ground.
it should camber in and fit.
when my wheel was mounted is was poking out be like 5mm or so.
put ut on the ground and it tucked.
same with the rear.
but rear rubbed a little bit so i did a pull on top of the roll i had already.
i only had to hammer the fender lips up front and camber to fit.
WUT?
