Old 02-15-2010, 09:57 PM   #1
D.Adams
D.Adams's Avatar
D.Adams is an unknown quantity at this point
Send a message via AIM to D.Adams Send a message via MSN to D.Adams
SR sr20 Clutch WTF
OK I bought a spec stage 3 clutch had my flywheel resurfaced also i did my rear main seal while i was working on that end of the motor. but now i have a major clutch slip under hard acceleration in every gear. i did everything rite this isnt my first clutch job im just at a dead stop with this.
motor
b/t sr20 with a t28 dont think i have the hp to slip this clutch.
can you guys give me some ideas. why is this clutch doing this?
“About the time we think we can make ends meet, somebody moves the ends.” ―Herbert Hoover
The build
http://zilvia.net/f/builds-builds-on...u-city-az.html
Owner of NVS Fabrications
D.Adams is offline   Reply With Quote
Old 02-15-2010, 11:37 PM   #2
Sileighty_85
Sileighty_85's Avatar
did you wait for the clutch to break in?
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 02-16-2010, 12:37 AM   #3
jdm213
jdm213's Avatar
jdm213 is an unknown quantity at this point
its probably you clutch master cylinder, thats what cause my slippage when i had my new lightweight flywheel and clutch kit put on, or your pedal is too high when you engage the clutch ???
jdm213 is offline   Reply With Quote
Old 02-16-2010, 01:29 AM   #4
D.Adams
D.Adams's Avatar
1500 + on the clutch before hard driving.
The build
Old 02-16-2010, 01:30 AM   #5
D.Adams
D.Adams's Avatar
yea the pedal is real soft and ingages at the verry top of the pedal. ill look at both
thanks
The build
Old 02-16-2010, 02:27 PM   #6
SrRaycer
SrRaycer is an unknown quantity at this point
It doesn't take that many miles to break it in. It also depends if its highway or city driving. I beleive 300-500 is recommended. I live in NYC and with the amount of stop-and-go driving, (and my light flywheel, which forces me to take off from a higher rpm) after 150 miles I would be comfortable thats its broken in.
Just my .02... no receipt needed
SrRaycer is offline   Reply With Quote
Old 02-16-2010, 02:40 PM   #7
jdm213
jdm213's Avatar
thanks
yeah adjust it and bleed from both places slave and clutch master
Old 02-17-2010, 01:00 AM   #8
D.Adams
D.Adams's Avatar
i driver 120 miles a day 60 one way then 60 the other for work it's all not stop because its highway driving. when i got the clutch from spec the rep that sold it to me reccomended 1200-1500 on normal driving. i dont use my car other then a D/D and a lil track time like once a year.
i know the clutch is broke in. my ka clutch was broken in at 300miles
thanks no worries..
The build
Old 02-17-2010, 05:07 PM   #9
D.Adams
D.Adams's Avatar
well i adjusted the pedal and bleed the slave cylinder helped a lil but still slips. i have sent a email the spec to see what can be done
The build
Old 02-17-2010, 06:44 PM   #10
jspaeth
jspaeth's Avatar
You've said this twice, but this would have no effect.
The pressure plate WANTS to keep the clutch squeezed against the flywheel.
The only way this is not happening is:
A) wrong pressure plate/clutch
B) not tightened down correctly
C) preloaded the clutch (need to adjust the clutch pedal out some and rebleed).
Daily driven
Old 02-18-2010, 12:49 AM   #11
jdm213
jdm213's Avatar
my bad, well anyways maybe you clutch master is leaking, you should definatley inspect the ruber boot of the cylinder, probably loosing some pressure there to engage the clutch properly
