Old 03-16-2010, 10:29 PM   #1
saleaf
saleaf's Avatar
saleaf is an unknown quantity at this point
s13 Start up Problems single cam
So i have trouble starting up my s13 ka. it will crank and try to start but it wont turn over untill a few good attempts. after that i have to play with the peddle to keep her running. but after about 30seconds to a minute shell idle fine. im looking for some opinions as to what it might be causing this. i have tried to adjust the idle and it worked but but no help with start up, only after shes a little warmed up. im just trying to get it to the point that it will start up easier. and idle good from there. i just recently got this car so im trying to delay tearing it all apart.
saleaf is offline   Reply With Quote
Old 03-18-2010, 03:38 PM   #2
dsastr_clan
dsastr_clan is an unknown quantity at this point
i had the same problem it drove me nuts!! i checked all the major stuff first and i couldnt figure it out till a few months after, i cleaned the battery terminals and terminals really good with a metal brush and also made sure that my ground wire was hooked up very tight replaced my ground wire that was rotten and after that brrooooommmm right away!
dsastr_clan is offline   Reply With Quote
crank, s13, single cam, start up
