Old 11-25-2008, 12:35 AM   #1
sideways performance
sideways performance's Avatar
sideways performance is an unknown quantity at this point
s13 s14 sr20de in s13 cold start issues
i guys,
I browsed through the threads and don't find any that could help shed light to my problem.
I am currently facing a "Cold-Start-Problem" (i think). I find it very difficult to start the car first thing in the morning and when I left the car parked for > 4 hours. The starter cranks but the engine just won't turn over. I would need to crank it 6-9 times before the engine kicks in. Flooring the gas pedal only works occasionally. Once the engine starts up, subsequent start up is a breeze (until I park it for > 4 hrs or so).
sideways performance is offline   Reply With Quote
Old 11-25-2008, 12:45 AM   #2
Z33dori
Z33dori's Avatar
yea mine does this 2....
alot ppl talk of this orange 12v wire to the ecu, but that is all they say.... so i don't know what to look for b/c there are like 4-5 orange wires...
and i have a shat box starter
Old 11-25-2008, 12:50 AM   #3
mobilesuit818
mobilesuit818's Avatar
mobilesuit818 is an unknown quantity at this point
A lot of cold start issues is fuel related in my opinion.
The colder it is, the more fuel it will take to start/run it.
There is something that is not sensing that in your engine.
Any good mechanic should be able to track that issue down.
Quality is not expensive, its priceless.
mobilesuit818 is offline   Reply With Quote
Old 11-25-2008, 01:18 AM   #4
Z33dori
Z33dori's Avatar
^ you make a good point
i have thought of it being a fuel problem... but i have no clue on where to start looking...
Old 11-25-2008, 02:00 AM   #5
Serebros
Serebros's Avatar
Serebros is on the path to ruinSerebros is on the path to ruinSerebros is on the path to ruin
Send a message via AIM to Serebros
get rid of the clutch interlock relay
wire the key directly to the starter
this may not be your problem, but i had the same symptoms, wouldn't start in real cold or real hot or if i haden't started it in a long time
easy 4 wire soder job on my ka in s13
late
Horsepower Sells Cars, Torque Wins Races - Carrol Shelby
Serebros is offline   Reply With Quote
Old 11-25-2008, 05:13 AM   #6
Sileighty_85
Sileighty_85's Avatar
Sounds like a bad Coolant Temp Sensor, check ECU for Code
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 03-11-2010, 11:30 AM   #7
racerocket
racerocket's Avatar
racerocket is an unknown quantity at this point
I have the same problem on my sr and check for codes, nothing pops up.
the beast is runing
racerocket is offline   Reply With Quote
Old 03-11-2010, 12:42 PM   #8
obsolete
obsolete is an unknown quantity at this point
this is an infamous issue. nobody ever posts of how they resolved it or if they did at all. same problem with my s14 sr20
obsolete is offline   Reply With Quote
Old 03-11-2010, 01:36 PM   #9
93nismo
93nismo's Avatar
93nismo is an unknown quantity at this point
i just had a thread about my ka not starting right. dave said to check the coolant temp sensor. that wasn't my issue but from what he described it as it sounds like it could be your issue.
http://zilvia.net/f/engine-tech/3078...-problems.html
its the second post by z u l8r i believe that he describes the sensors function.
WTB: 1/24 scale chuki s13 model.
93nismo is offline   Reply With Quote
