Old 06-18-2003, 09:12 PM   #1
matt0941
matt0941's Avatar
matt0941 is an unknown quantity at this point
Send a message via AIM to matt0941
Bungs: Revised (KA-T)
OK I am getting bung crazy tell me if I don't need any of the following or have their positioning wrong for my KA-T setup. (EGR is optional but I may want to run it later on)
EGT (Exhaust Gas Temperature) Bung in the #1 cylinder runner of the exhaust manifold
EGR (Exhaust Gas Recirculation) Bung in the downpipe
o2 Sensor Bung in the downpipe
wideband o2 sensor Bung (for dyno tuning)
Your comments please.
Troubleshooting? Fresh Alloy
matt0941 is offline   Reply With Quote
Old 06-19-2003, 12:34 PM   #2
Kreator
Kreator's Avatar
Kreator will become famous soon enoughKreator will become famous soon enoughKreator will become famous soon enough
ummm move the egt to the downpipe. You are looking for a difference in temperature here, not the actual temperature itself.... maybe for tuning purposes u need the actual tempperature, but it could be approximated. Plus the exhaust manifold (especially cast iron) is not something i would mess with and it costs ~3-4 times more than yer dp (in case u screw it up). Oh and u must have egr unless u are ok with check engine light always on and emissions being much worse. Its definately much easier to get a bung for the egr on then mess with the sensors...
and why would you need 2 sensor bungs? I'd guess you can use the o2 sensor hole when u tune with the wideband sensor and then replace with a normal sensor once your done.... or you plan on running 2 sensors?
кто болеет за Зенит, у того всегда стоит!
Kreator is offline   Reply With Quote
Old 06-19-2003, 11:10 PM   #3
Warwick5s
Warwick5s's Avatar
Warwick5s is an unknown quantity at this point
heh heh heh...BUNG
Warwick5s is offline   Reply With Quote
Old 06-20-2003, 07:46 PM   #4
matt0941
matt0941's Avatar
Lol
But thanks for the reply kreator, as for your idea of taking out the o2 sensor and replacing it with the wideband for tuning, would this work?
if it did it would save me some time, can anyone else comment?
thanks
Old 06-20-2003, 07:51 PM   #5
Kreator
Kreator's Avatar
i think it should... i'm not sure if your car will run on just the wideband sensor alone (should, but i don't want to mislead u). As for fitting, i think they all use the same thread pattern (my 240 sensor screws in volvo 740 downpipe). Plus if you drill 2 holes, you'll have to be plugging one up after you are done.... doesn't sound right.
