Old 03-11-2010, 04:04 AM   #1
Jung2
Jung2 is an unknown quantity at this point
Resonator and Catalytic for S14?
Does this two have the same bolt patter? Can you bolt the catalytic in place of the resonator? Thanks.
Jung2 is offline   Reply With Quote
Old 03-11-2010, 04:22 AM   #2
mxexux
mxexux's Avatar
mxexux is an unknown quantity at this point
I believe the cat is bolted in and the resonator which is further downstream is welded on my friend.
mxexux is offline   Reply With Quote
Old 03-11-2010, 04:29 AM   #3
Jung2
Sorry but my S14 resonator (aka dummy cat) is bolted.
Old 03-11-2010, 05:57 AM   #4
murda-c
murda-c's Avatar
Yes you can put a downstream cat in place of a dummy cat, i did it.
Old 03-11-2010, 06:09 AM   #5
Jung2
Was it a direct bolt on?
Old 03-11-2010, 06:46 AM   #6
murda-c
murda-c's Avatar
Yup, i took out my cat and put in a test pipe, and my friend took the cat and put it in place of his dummy cat.
you might need new hardware but I can't be sure because mine was too rusted to reuse.
I'd recommend new stainless hardware and some anti-seize lube.
Old 03-11-2010, 03:59 PM   #7
projectRDM
projectRDM's Avatar
It is indeed a direct replacement, any 89-98 piece will fit in any exhaust, whether it's a real converter or not.
FORMERLY R240NA
Old 03-11-2010, 04:19 PM   #8
Jung2
Thanks for the info guys!!! I will order my cat today. Hope this help quite down my S14. Again thanks
