Old 03-05-2010, 07:52 PM   #1
zbear
zbear is an unknown quantity at this point
Megan Racing Coilover Damper Kit Street Series Nissan 240SX S14 New
On car less than 100 miles.
For 1995 1996 1996 1998 Nissan 240SX S14
The Megan Racing Street Series Coilover Damper Kit is excellent upgrade to your street car. Featuring 32 levels of damper force and full-height adjustment, the Megan Racing coilover damper kit will enhance your car's handling performance.
The adjustment of the damper is simple with a built-in knob at the top of the damper mount for easy access. Simple adjustments can be made to tune to your style of driving and comfort level desired.The height adjustment is made easy with CNC-machined locking perches for accuracy and smooth adjustment. You can raise your car up to factory height for OEM appearance with performance handling or you can drop your car all the way down for an aggressive stance lowering your center of gravity to gain full potential of your car’s handling capabilities.
On many car applications, the Megan Racing Coilover Damper Kits come with fully adjustable Pillow-Ball upper mounts to easily tune and adjust your camber (see specifications table below). Adjustable camber gives you an edge on most suspension setups, as you can easily tune your car for any ride height, improving your car's handling, predictability and tire wear.
Megan Racing coilover damper kits are manufactured for quality and durability. The springs that are part of the coilover damper kit are constructed of SAE-9254 cold-wound steel and tested over 500,000 times by compression inspection. These have deformation of less than 5% and high strength sophisticated surface coating. Megan Racing stands by its products with a 1-year limited warranty
Megan Racing Street Series Coilover Damper Kit Features:
- Pillow Ball Upper Mounts w/ Camber Adjustment (Front Only)
- Rubber Dust Covers
- Adjustable Ride Height
- Aluminum Brackets
- All Hardware is Included
- All coilover damper kits come with 1 year manufacture-defect warranty
32 Levels of Adjustment:
- 1-8: Suggested for track use.
- 9-16: Suggested for mountain/aggressive use.
- 17-32: Suggested for common street use.
Reference: Megan Racing Street Series coilover damper kit, Megan Racing coilover, Megan Racing damper kit, Megan coilover kit, Megan SS coilover kit, Megan Street Series coilover
Front Rear
Spring Rate (kg/mm) 8 6
Camber Plate Yes
Damping Adjustability 32 ways adjustable
Located in Northern California
(510) Area Code
Berkeley, CA 94701
Check my feedback at my350z.com forums. Same username: zbear
$700
$40 Shipped anywhere within the US
Paypal add 3%.
zbear is offline   Reply With Quote
Old 03-05-2010, 08:15 PM   #2
illest
illest is an unknown quantity at this point
just out of my price range..
GLWS
illest is offline   Reply With Quote
Old 03-06-2010, 12:32 PM   #3
s14vqswap
s14vqswap is an unknown quantity at this point
still got them
ship to 14086 i really need them!
s14vqswap is offline   Reply With Quote
Old 03-13-2010, 11:03 PM   #4
zbear
Weekend bump!
