Old 03-28-2010, 06:39 PM   #1
PNgo12
PNgo12 is an unknown quantity at this point
differential question
im taking out the welded diff on my car right now and i cant seem to keep the driveshaft from moving, i took out all the bolts from the axle and now im taking out the bolts that connects the diff to the shaft and when i turn the bolt the shaft moves so it moves the whole thing, ive put the car in gear and the E brake is on but it still moves, (it does move when i turn it by hand when the car isnt in gear and without the e-brake being on but the bolts are so tight its taking the shaft with it when it IS in gear)
PNgo12 is offline   Reply With Quote
Old 03-28-2010, 08:35 PM   #2
az_240
az_240's Avatar
Trader Rating: (41)
az_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really nice
Feedback Score: 41 reviews
Send a message via AIM to az_240
^you're ebrake doesnt work or is extremely weak or you just didn't put the bolts back into the axles. Put the bolts back into the axles and have someone step on the brakes to crack them loose.
These bolts are always a bitch for me. Can't get a socket on them so I have to use a broken wrench and a breaker bar.
az_240 is offline   Reply With Quote
Old 03-28-2010, 08:42 PM   #3
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
^^ what he said step on break or ebrake it that the only way unless you can get your hands on an impact wrench
S-Nation S13 is offline   Reply With Quote
Old 03-28-2010, 09:59 PM   #4
PNgo12
i put the bolts back in into the axles put it in gear and ripped the E-brake, then muscled the bolts and they came out, i guess i took out the bolts on the wrong order, thanks guys
Old 03-28-2010, 11:20 PM   #5
lflkajfj12123
haha funny shit i did the same thing earlier
just put two bolts in each axle to keep it from moving
Old 03-29-2010, 08:13 AM   #6
projectRDM
projectRDM's Avatar
Next time just side a wedge bar into the rear u-joint and hold the driveshaft in place.
FORMERLY R240NA
