Old 06-29-2003, 04:29 PM   #1
Sleeper s13
Sleeper s13 is an unknown quantity at this point
Nissan rear dif. gear ratios
I was wondering what different gear ratios in limited slip differentials nissan has employed in their sports cars like the skyline,Z car, and the 240sx/silvia (past thru present)? and if anyone knows, also the possible hp tolerances of each. a legitimate tech web page would be great.
Sleeper s13 is offline   Reply With Quote
Old 06-29-2003, 06:37 PM   #2
mrdaniel
mrdaniel is an unknown quantity at this point
Infiniti:
Q45 : 4.09 R230 LSD - this diff can take ~475rwhp
J30 : R200V
Nissan:
Skyline : R200 4.3
280ZX : R200 with 3.54 3.90 4.11
300ZX : R200V
240SX : R200 or R200V
mrdaniel is offline   Reply With Quote
Old 06-29-2003, 08:41 PM   #3
orion::S14
orion::S14's Avatar
To elaborate:
Q45 does have R230, but I believe it's the 3.69 ratio, same as the Z32 TT (they share rear diff, subframe, etc...and it DOES NOT bolt into the S-chassis)
J30 comes with 3.916 ratio, R200V
300ZX: N/A = R200V, 4.083 ratio, same as S13/14...
Z32 TT = 3.69 - see above
240SX comes with 4.083, either VLSD or open
180SX from Japan came with 4.083 and 4.36, both in an R200V case
Nissan Motorsports offers a 3.7, 4.36 upgrade and a 4.64 upgrade for the R200(V)...
Later - Brian
Old 06-29-2003, 08:56 PM   #4
mrdaniel
Q45 well the ones i've used at least are R230 LSD with 4.09 rear gear. not 3.69
Old 06-29-2003, 09:22 PM   #5
orion::S14
orion::S14's Avatar
Not trying to be argumentative, but to clarify this point:
- - 1997 Q45 specs - -
- - 2001 Q45 specs - -
Maybe they were different in years before 1997...Infiniti did do a lot of redesign then.
And it seems maybe those were Touring models - I could see how the regular Q45 would have a numerically higher ratio.
Later- Brian
