Old 07-02-2003, 10:23 AM   #1
muskrat
muskrat's Avatar
muskrat is an unknown quantity at this point
s13 Radio Install Questions
OK, I've been installing car stereos myself for over 10 years, no professional experience, but I know what I'm doing.
Anyway, I have a 1992 240sx SE coupe. When I got the car it had no radio in it. So I got an aftermarket radio out of an '89 or '90 240 coupe. The radio didn't work, but it had the wiring adapter, so last night I hooked the harness adapter to a new CD player and installed, after a little poking around, I had to move the 12v switched and ground pinouts on the adapter, so I guess they are different from the '89-'90 model and the '92. Are there other wiring differences in the models?
I ask because so far no sound from the speakers. It's either the wiring is all different or they are maybe wired through an OEM amplifier or something.
Any help would be greatly appreciated.
muskrat is offline   Reply With Quote
Old 07-02-2003, 12:27 PM   #2
radhaz
radhaz's Avatar
radhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud of
There were oem amps on some models and there is a write-up available on how to bypass them if thats the case. Your best bet would be to do a search of the forums on the subject and find that and see if that helps.
Need a 96 driver side window switch. Feel free to pm me with a price
radhaz is offline   Reply With Quote
Old 07-03-2003, 07:17 AM   #3
muskrat
muskrat's Avatar
Originally posted by James
Teh 240 sound system is retarded.
Might as well run new wires throughout the car.
Well, I bypassed the rear amplifier, just wondering if the front speakers had their own amp or if they were powered by the deck? Rear speakers are now working, but the fronts are not, so either they are run by an amp, there are no speakers behind the grilles, or the speakers that are there are blown.
Old 07-03-2003, 03:26 PM   #4
RedlineRacer
RedlineRacer is an unknown quantity at this point
Send a message via ICQ to RedlineRacer Send a message via AIM to RedlineRacer
Yeah, the fronts have a factory amp too. I ran new wires like James said. It's not worth the trouble trying to wire throught those crappy amps. You aftermarket cd player will put out more power than that factory amp will.
RedlineRacer is offline   Reply With Quote
Old 07-10-2003, 07:49 AM   #5
muskrat
muskrat's Avatar
Where is this amp located so that I can bypass it at the amp. Thanks.
Old 07-10-2003, 02:16 PM   #6
Yoshi
Yoshi's Avatar
Yoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to behold
I THINK, that only the front speakers have the amp thing, they're actually wired to the speaker itself, into the door, yank the whole big plastic/metal assembly out, no missing it
www.360realms.com/S13-S15
Yoshi is offline   Reply With Quote
Old 07-10-2003, 10:07 PM   #7
cdlong
nope, the rears have an amp too, i just pulled it out yesterday.
i had an aftermarket headunit with factory speakers running for a while and it worked fine. i guess you could pull out the amps, but it should work with them in there.
cdlong is offline   Reply With Quote
